Release Notes 2017.1
Introduction
We are proud to deliver you Version 2017.1 of our RadiMation® EMC Test software. This 2017.1 version is the result of several major improvements that we have done.
We include several improvements and new functionalities in version 2017.1, the most important improvements are:
- Graphs filtering in multiband immunity, which fixes the overwriting graph problem
- 1 Hz on/off software pulse modulation
- New user interface for Sequence configuration window.
- Several user interface and usability improvements.
- Report generator fixes.
We trust that we have incorporated these new feature in such a way that it is useful for several customers that have been requesting these functionalities.
This letter contains all the information that is needed before your system is upgraded. If you have any additional questions or remarks please let us know through your reseller, or contact radimation-support@raditeq.com.
Installation
Backup
- Correction files
- TSF files
- Sequence files
- Limit Line files
Multi version installation
Be advised that:
Installation
Installing software updates
Updating device drivers
Verification and Validation
1) Automatic knob pushing program
2) Validation and usage in a test lab
3) Validation and usage in a test house
4) Validation by end-users
Solved items
See below the list of all the issues that have been solved in RadiMation® version 2017.1 since version 2016.1
RadiMation version 2017.1.7
- #6971: Driver: LeCroy WaveSurfer and Wave Runner oscilloscope series
- #8538: Driver: CPI Amplifier J-series
- #8541: Option to enable/disable frequency correction of PMM EP600-series
- #8553: Support Mode 4 of the RadiPower
- #8555: ErrorReport: "Collection was modified; enumeration operation may not execute. "
- #8565: Driver: Steatite atennas
- #8566: Driver: Flann Microwave antennas
- #8569: Use Internal 10 MHz out for IFR 2023 Reference clock
- #8582: Support the Preamplifier of the new TDEMI X
- #8623: line coupling is only showing 1 line coupling in VDI TSF configuration
- #8662: Object reference error while using minimum performance in a MB magnetic field closed loop method test
- #8685: AD Channel colors are the same
- #8689: Note field cannot be larger then 1000 characters.
RadiMation version 2017.1.6
- #4969: CANoe interface object not initialized correctly
- #7496: Sentinel dongle failure
- #7586: Not possible to export attached pictures in the report by using the Report Generator
- #7696: Graph is not showing (correct) trace data during CI calibration and RI Multiband
- #7829: Implement the AnalyserAsPowerMeterDecorator for ESU and ESI series powermeter device drivers
- #8062: Outside Points
- #8068: Marconi 2042: Specific System Error: 2
- #8165: Ability to use AM modulation with the obsolete Agilent Technologies E4432B Signal Generator
- #8287: Extend R&S ESCI driver to allow selection of CISPR-Average or (old-)Average as Average detector
- #8340: Ability of 'Power Measurement' settings for the R&S ESR7 to avoid unexpected bandwidth jump behavior
- #8378: Enabled Calibration before final measurements option causes GPIB: EABO timeout
- #8384: External reference setting of the R&S ZNB is changed during initialization
- #8403: Rotate to position after end of test (de-initialization)
- #8412: Ability of 'Power Measurement' settings for the R&S ESU40
- #8429: Opening of a very large CI Multiband test is very slow
- #8431: Unclear description when the RadiSense is still in standby
- #8444: Driver: BiDirectional Coupler BDC 0660-30/100
- #8446: Driver: Teseq CBA 1G-150 amplifier
- #8450: ESPC Not all bytes are written to the GPIB board "Perform short calibration before final measurement" option
- #8452: IFR 2052 driver is not working correctly
- #8467: RI Multiband AM modulation is only used for first point, after that its none if modulation conservation is activated
- #8477: RadiLog Error Report does not make screenshot from external monitor
- #8479: Maturo MCU raises a Lock error during deinitialization
- #8481: Driver: RSSA3021X Spectrum analyser
- #8483: R&S ESIB40: Function not available;FREQ:STOP:LINK START
- #8488: N9038A: System Error: -410: Query Interrupted
- #8493: CARAD software invalid messages received
- #8503: Marked peaks are not saved
- #8504: Minimum power of CI Fixed power test is -40 dBm
- #8508: Ability to select Internal or External reference clock on some devices
- #8510: Changing unit causes crash
- #8511: Frequency correction of PMM EP603
- #8512: Device Driver: Marconi 2052
- #8518: Not possible to generate a printout of the amplifier linearity test results
- #8523: Compression test table: uses wrong unit in time and frequency column
- #8526: Generated power of CWS500N1 drops at 350 kHz
- #8527: RSSML Merge reference source
- #8556: Negative power reading of NRP-Zxx powermeter
- #8557: Wrong de-initialisation NRP-Zxx
- #8573: Driver Antenna Schaffner Bilog
- #8584: Driver: PMM EP604
- #8602: Driver: Multimeter Agilent 34401A AC and DC measurement
- #8603: Driver: generic configurable coupler for the couplers of ATM Microwave
- #8604: Driver: generic configurable coupler for the couplers of RF Lambda
RadiMation version 2017.1.5
- #7633: Unexpected oscilloscope measurement value of first frequency point
- #7652: Configurable Injection Device custom frequency range is not retained
- #7689: Graph export is showing unexpected end frequency
- #7901: ControllerDelay for a GPIB controlled Maturo MCU can be 0
- #8092: When a printout is generated and printed the 'busy' dialog should be shown, to indicate that the PC is busy
- #8113: Unable to communicate with CWS500N 1.2
- #8233: RadiMate slow measurement speed
- #8247: Tektronix Oscilloscope returns No data or incorrect data was returned by the device
- #8334: No measurement data during "Continuous Measurement" as altitude scan using CO3000 controller
- #8406: Password of a new engineer is unknown, and cannot be changed
- #8408: EUT Monitoring channel Maximum and Minimum Limits are not shown
- #8418: Maturo NCD over lan
- #8419: Settings in 'Fixed step count' frequency step setting in a multiband immunity test is not remembered
- #8420: Fixed step count as step frequency in multiband immunity is not working when 'per octave' is selected
- #8421: Agilent E4422B unable to connect
- #8422: Singleband GTEM emission data is not shown when a dot is used a decimal symbol
- #8423: HP 34401: Timeout while waiting for *OPC command
- #8425: VDI duplicate band Object reference
- #8430: Internal AM modulation on the Agilent E4422B is not supported
- #8433: Exporting of graph data to CSV is not always in Excel compatible format
- #8435: Allow control of CANoe 9.0.65 (SP2)
- #8436: Also notify the CANoe CAPL interface of dwelltime start and dwelltime end
- #8437: Possibility to leave CANoe running when the CANoe switch matrix is used
- #8441: Changing polarization of Frankonia FC02 raises 'Illegal parameter value' error
- #8448: Destination array was not long enough. Check destIndex and length, and the array's lower bounds.
- #8451: CWS500N Checksum error
- #8455: Black lines in RI tests
- #8456: Conducted RF immunity stepsize 0,5 per cent not possible
- #8461: Preselection filter before the test
- #8464: Changing region settings causes data loss.
- #8469: Agilent Technologies E4422B: "Undefined header" when turning off AM modulation
- #8475: When changing step frequency of 1 band, all the bands step sizes change.
- #8476: R&S ESI: Function not available: INP:GAIN:STAT OFF, when FFT filter is used
- #8485: Changing test level settings after its loaded by TSF, is not using last setted device.
- #8486: Export EUT filename shows TSF filename
- #8515: Driver: emtest esd NX30
- #8519: Missing NIPALU.DLL error when starting RadiMation
- #8536: Merge test blank page
RadiMation version 2017.1.4
- #6093: Turntable CO3000 is not moving when setting it to make a full turn from 0 till 360 degrees
- #6798: Apply multiple testlevels at same frequency
- #7780: Exporting EUT executed tests list
- #8207: Configurable Device driver frequencies with different units
- #8244: Climat typo it should be Climate
- #8301: Unhandled exception access to the path ErrorModeFile.radilog is denied
- #8322: RPR2006C overranges during CDN voltage calibration
- #8371: 1% Stepsize in RI Manual mode is not correct when a frequency list is used
- #8382: ODBC customer database is not working anymore
- #8383: Store RADIMAT_SESSION.LOG in a PC local temporary folder
- #8389: Received power is rounded in Antenna Scan EUT Calibration
- #8397: Searching for a customer in the customer database closes the window before the customer can be selected
- #8399: Loading a multiband immunity test is not possible, unable to create VSWRGatherer
- #8415: RadiMation crash at startup after updating to 2017.1.4
- #8416: Agilent N9000A (version A.07.06) Error with GPIB
- #8426: Unable to select correct OPC channels for AD converter.
- #8443: Driver: Amplifier BLMA 1060-50
- #8458: Unable to connect to radigen RADIGEN0230A
RadiMation version 2017.1.3
- #8210: Opening a RE Multiband test is taking one and a half minutes
RadiMation version 2017.1.2
- #8045: RDC files are always stored to the Global configuration path while standalone setting is used
- #8091: Improve calculation of multiband immunity graphs
- #8097: Linear and logaritmische scale setting are not saved
- #8145: Unable to show AD Channels in 2017.1.1
- #8199: Opening Multiband Immunity results takes a lot of time since graph filtering is implemented
- #8238: Language file 0.lng
- #8363: RadiLog option in view menu incorrect behaviour
RadiMation version 2017.1.1
- #506: 1 Hz on off modulation is not possible according to the DO-160E / ED-14E standards
- #2947: Amplifier is turned off when closing another multiband test
- #3032: Opening an Multiband test while performing a Multi band test is messing up the test
- #3241: RI multi band test is overwriting the previous information
- #3598: Configurable Peak Table
- #3970: Radiated emission multiband: detector from pre-measurement used during "continuous measure"
- #4001: Difficulties to differ results from 2 bands with the same frequency range in multiband immunity tests
- #4159: RBW in peak table (RE multiband)
- #4248: Error Multiband start and end frequency
- #5189: Sweeptime is used during final measurement instead of the QP measurement time
- #5216: Test started event log entry should only be added in a restarted multiband test if manual or automatic is pushed
- #5307: Despite of no changes the message "The file has changed, do you want to save changes?" is shown
- #5341: After a Manual Mode change there is undesirable regulation
- #5440: Can't zoom out after maximum zoom in at graph
- #5469: Invalid Device Driver Handle error (Kalmus 727LC)
- #5529: Invalid Device Driver Handle (Virtual) Amplifier
- #5545: Graph is not updated when switching to the second band
- #6075: During instable measurements it may happen that Peak and Quasi-Peak measurements are inconsistent
- #6191: Add an 'Add Test' button to the Sequence window, to simplify the addition of a test
- #6230: Table export only copies the time and frequency data
- #6264: Overlapping bands in MB immunity are tested multiple times when only the modulation is different
- #6352: Changing the activated detector during Continuous Measure clears the measured value of the deactivated detector
- #6449: Frequency range settings are generating an error and the configuration of the TSF is lost when a read only test is saved as new test
- #6452: Frequency array calculation of emission sweep of analyser is missing a step
- #6861: Radiated Immunity Multiband is referring to a receiver
- #6907: Improve autosave functionality that it no longer overwrites the current test data, but first makes a backup
- #7074: Possibility to change polarization of an existing calibration file
- #7077: continuous measure is using sweep time setting
- #7143: RI Multiband only shows Puls when AM is also selected
- #7147: Redoing an already performed test overwrites the previous test-results
- #7167: Amplifier linearity measurement accepted power lines hidden
- #7177: Unable to zoom graph while test is running
- #7203: A generic error occurred in GDI+
- #7214: PI windows still do not fit at full window size using an acceptable resolution
- #7242: Two electrical field graphs are shown. Which one is correct?
- #7247: Prana amplifier is not correctly being put in Operate during immunity test
- #7249: Show example of unit settings
- #7252: RadiMation Free Responsiveness
- #7254: Change Basic small controlling window for PowerMeter
- #7255: Change Basic small controlling window for Amplifier
- #7365: Minimum size of 'Burst' and 'Envelope Tracing' tabs of the VI Powermeter
- #7411: Connection state is still orange while the device is already connected
- #7441: Minimum Form Size is always set to 0,0 at runtime
- #7449: VI Powermeter error lock when removing device
- #7499: RadiMation opening EUT is slow
- #7523: PI EFT Test levels are not covering all the different measurements
- #7575: RadiLog long tests multiple log files.
- #7581: Test description of the test is not visible in the test data
- #7637: Driver: emtest UCS500-M4
- #7644: Filling the EUT information is being slow.
- #7717: Unchanged LLF is asking to be saved when closing the window.
- #7721: System attenuation gain duplicate measurements
- #7737: Report generator query keyword for the table information is not exporting any data
- #7760: Ability to merge multiple Radiated Immunity CALibration files for different frequency ranges into one
- #7768: Wrong frequency at monitoring input events
- #7769: Saving tsf as ReadOnly data lost
- #7773: Incorrect table information for frmVIPowerMeter at the ctlControlGraph table
- #7779: Overlapping bands in MB immunity are tested multiple times when only the modulation is different
- #7796: Compression Gain System Calibration default 1 amount of samples seems to result in a corrupt calibration file
- #7799: Sorting of the ctlFormattableGrid is different when new columns is added
- #7811: Clear button on the VI Fieldsensor doesn't seem to work when the table is shown
- #7812: VI Fieldsensor keeps raising error messages when the probe is turned off before it is disconnected
- #7819: No data document could be created for the test identifier: "
- #7820: Test specific templates are gone after graph customization
- #7824: Reflected power input in Multiband Immunity
- #7836: Connect button is not showing 'Connecting'
- #7842: Saving EUT file with keywords
- #7844: Incorrectly saved Test results starts the test when reviewing the Test results
- #7845: PI test EUT cable selection should be changable while TSF is read only.
- #7866: Corrupt file saving when validator failed.
- #7867: Out of memory when starting RI test
- #7878: RadiLog error report containing # in description gives error.
- #7885: Test data like notes and specific templates settings are updating or overwriting EUT overview settings
- #7886: Resizing of the Graph customization window hides some graph customization controls
- #7887: Missing keyword in Table shifts the table
- #7893: Data file is not saved every 5 minutes, when a final peakmeasurement is busy
- #7894: Radilog memory is not being swapped
- #7896: Missing last test frequency in ReportGenerator output
- #7897: Error Report send not always sending
- #7898: & sign in device driver name is not correctly shown in the EUT Monitoring dialog
- #7902: MessageBox that is shown from the testsite before actions can be shown behind the main window
- #7903: Unable to start RadiMation with incorrectly configured path
- #7904: Default table settings are stored in the user interface
- #7905: ReportGenerator Report and output file selection is not saved.
- #7908: Invalid tsf in sequence can corrupt the sequence
- #7915: Merging of calibration files looses the originally desired fieldstrength
- #7918: Graph customization window can be made too small
- #7922: External modulation should not be possible for a VI signal generator
- #7926: The RBW value has changed by the device from 120 to 100 User description:
- #7927: Duplicate more than 1 test at the same time in the new Sequence window.
- #7932: Very long filenames of the RadiLog file cannot be opened by RadiLog
- #7937: Signal generator VI frequency can be set outside the range of the controlled device
- #7940: Why is the Peak Table disabled during an Emission test?
- #7946: Opening test results directly sets the changed flag.
- #7947: Switching to a different band using 'Continue automatic mode settings' is incorrectly checking if the carrier frequency is valid
- #7950: Ability to hide Report Generator Template column for 'The keyword "" is available in the tempate' window
- #7951: Sending unprintable characters with configurable device driver
- #7953: Frequency list settings are not saved for a sequence and thus not used when Fixed power test is run from within a SEQ file
- #7955: Size of Voltage Dips and interrupts TSF window can be made too small
- #7962: RadiLog to long subject gives error. Strange behaviour occurs.
- #7963: RadiLog parsing fail
- #7964: Directly after installation, the power graphlines are not shown in the VI Powermeter
- #7965: A read only TSF is also asked to save the changes
- #7966: Last View update is being skipped
- #7969: EFT tests with repetition rate 100 kHz (burst duration 0,75ms) can NOT be performed
- #7971: Radilog saving file, file in use while reporting error.
- #7980: Test data files are zero based count on disk which is confusing for end-users
- #8003: Clear graph button for VI windows does not work (when disconnected)
- #8004: Opening of locked files should wait for a few seconds and retry opening locked files
- #8009: Opening a second CE Absorbing clamp test, switches both graphs from log to linear xaxis.
- #8011: Exporting polar graphs contains a white space area.
- #8015: Improve graphical representations of graph
- #8021: When a Band has been selected the TSF is marked as being changed
- #8029: Graphs during Multiband Immunity are not updated during test
- #8030: VI powermeter windows does not work correctly
- #8033: Combine user defined units to prevent multiple equal axis from being shown in graph
- #8040: Error window location cut off
- #8046: Error report, cant write to temporary directory
- #8053: EUT being removed after network reset.
- #8054: Manual frequency is not measured when it is exactly the same as the last frequency in the calibration file.
- #8061: Before actions are prompted multiple times at the end of the test
- #8069: Shortcutkeys not updating ctlEvents
- #8085: Gaps in graph lines.
- #8096: Auto detect peaks shows object reference error
- #8101: RadiLog SQL files containing ";" is not opening correctly
- #8104: RadiMation does not automatically refer and open the latest installed version
- #8106: RadiLog object reference after saving
- #8107: Errors are not reported in RadiMation
- #8108: Error window tooltip causes object reference error.
- #8109: Export full PEAK table
- #8112: Radilog Parsing error when opening log from zip
- #8114: Calibration Files do not use the same calibration method
- #8130: Virtual Instruments infinit loop errors
- #8137: Language files as unicode
- #8138: VDI Impedance is set incorrectly to the device
- #8140: VI Signal Generator all controls are still disabled after connected
- #8144: Exporting graph to LLF in the graph options crashes
RadiMation version 2016.2.11
- #7981: Device stays in remote after reaching the end frequency
- #8007: Turning of the MAHA turntable is not working
- #8051: ESIB 40 FFT mode cannot be active in zero span
- #8057: Harmonic Test Calibration with Aronia
- #8070: Driver: RadiSense 10 Field sensor
- #8075: Driver: Emtest CWS500N1 Signal Generator
- #8117: R&S ESPI 3 Impossible to get description string for this Error when opening ShowConfigurationDialog
- #8126: Driver: NoiseKen Amplifier
- #8128: Driver: EUT Monitor R&S UPV
- #8208: Frequency is not set in the PMM 8053A
- #8216: How to connect a Rohde & Schwarz NRP6A power sensor?
- #8217: Ability to set the R&S ESW26 Analyser number of points to a maximum of 32000
- #8231: Driver: Keysight Technologies 33612A Signal Generator
- #8242: Support 4 kHz option of RadiPower
- #8243: Unknown error in control of Climat Chamber
- #8250: Passive drivers CEATSA (ARSAT)
- #8251: Driver: Antenna tower controller ETS-Lindgren 2090 Positioning Controller
- #8252: Driver: Amplifier IFI S251-500
- #8253: Driver: Amplifier IFI T2575-500
- #8256: Driver: Powermeter NRP-Z55/NRP-Z5
- #8257: Crash with Fluke 8845A Multimeter
- #8259: Driver: special RadiSense justation device driver
- #8278: What is the latest RadiMation version running on Windows XP?
- #8286: Extend R&S ESR3 driver to allow selection of CISPR-Average or (old-)Average as Average detector
- #8289: Extend R&S ESPI7 driver to allow selection of CISPR-Average or (old-)Average as Average detector
- #8291: Driver: CWS 500N3 as Amplifier
- #8292: Driver: CWS 500N3 as Coupler
- #8293: Driver: CWS 500N3 as Powermeter (in V mode)
- #8294: Driver: CWS 500N3 as Current sensor (in I mode) as Multimeter
- #8295: Magnetic field testing ISO 11452-8 using the EMTest CWS500N3
- #8298: Driver: Virtual ESD device driver
- #8314: Communication is getting out of sync using a Configurable Antenna Tower driver
- #8323: Driver: is the Frankonia EFS 10 (EFS-100) Field sensor supported?
- #8326: Unexpected responses from RGN device seems to out sync and disturb communication causes "'Setting the output raised an error"
- #8328: LumiLoop LS Probe raises "Setting the frequency raised an error"
- #8333: How to tweak monitoring Field sensor measurements configuration for more reliable measurements?
- #8336: Low field strengths values are increasing signal generator carrier level to the maximum during 61000-4-3 calibration
- #8339: Are previous RadiMation version still usable after updating to a newer RadiMation version?
- #8343: Signal generator drivers (e.g. RGN0230A) raising Unknown Device Driver error
- #8345: Session for reconfiguration of the complete RadiMation installation
- #8348: PMM 8053A: Setting or enabling the frequency correction feature raised an error
- #8350: RF Relay Matrix Unit RFM-S3A3CILR and RFM-S2A2CILR and RFM-E521_231_241
- #8351: R&S ESI 26 Specific System Error: -200 Execution error; Option not available; SCAN1:INP:ATT 50 DB
- #8353: Adjust the RadiSense justation driver having the calculation accepting Signal Generator power levels
- #8367: RadiLog description containing a ";" removes 1 space
- #8369: Amplifier IFI S251-500 Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
- #8370: Amplifier IFI T2575-500 Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
- #8373: How to configure the used (EMI) filter of the equipment?
RadiMation version 2016.2.10
- #1391: 0% Step possible in Radiated and Conducted Immunity
- #5347: ESPC is returning a timeout error after CAL?
- #5907: Error detected during the start of the sweep with PMM 9010F
- #6331: Driver: Configurable Multimeter
- #6371: Driver: Signal Generator PMM3010
- #6415: Driver: IFI T188-500 Amplifier
- #6679: Driver: Tektronix TDS310 Oscilloscope
- #6680: Driver: Tektronix TDS3052B Oscilloscope
- #6681: Driver: Tektronix DPO3010 Oscilloscope
- #6691: Driver: Bonn Elektronik BLWA series amplifiers
- #6859: Driver: AR 1000W1000E
- #7299: Selection of Input 2 for the TDEMI X
- #7424: Keysight N9083A runs incredibly slow after 3.6 GHz in scanned receiver mode
- #7545: Driver: battery powered RadiField Polarizer RPL2010A
- #7567: Driver: ADC NI 9215
- #7646: Driver: Frankonia FC04
- #7694: Pulse modulation IFR 2023B Signal generator is not turned off by sending the correct command
- #7992: Measurement with FSV3 power meter is slow and instable
- #7996: Raise a warning that still an outdated or old version of National Instrument GPIB software is used
- #8018: Configurable Absorbing Clamp custom frequency range is not retained
- #8038: Hameg HMS3010 Spectrum Analyser Error: -222, "Data out of range"
- #8042: Hameg HMS3010 Spectrum Analyser is returning previous measured peak data
- #8048: PMM 9010 Comport already open error when using Userport Controlled LISN and receiver simultaneously
- #8049: Hameg HMS3010 Spectrum Analyser has restricted RBW filters for (receiver mode) QP detector
- #8050: RadiMation crashes when using Agilent N9038A
- #8052: Maturo MCU Turntable controller returns E-D error
- #8055: How to perform magnetic immunity calibration?
- #8060: How to make the dwell time depending on an external EUT monitoring device?
- #8063: Driver: Bonn BSA 1010-125 and generic series driver
- #8073: Driver: ETS-Lindgren 3142B Antenna
- #8074: Driver: ETS-Lindgren 11966P Antenna
- #8076: Driver: Injection device Luthi RF current Injection clamp
- #8078: Driver: CDN M2-M3N
- #8080: Driver: ESD Generator
- #8082: Driver: Bonn BLMA 1030-80 series
- #8084: R&S FSH 8 Field probe attenuator
- #8088: Gauss Instruments TDEMI: Specific System Error: -100,SYSTRF DEF
- #8089: Gauss Instrument TDEMI3G: Specific System Error: -220,"Parameter Error;SYST:RF DEF"
- #8090: RadiGen RGN start frequency can't go lower then 9 kHz
- #8098: RGN6000B "Data out of range" error when setting carrier level above 4.0 dBm
- #8100: Driver: TESEQ BHA 9118 Horn Antenna
- #8102: Driver: Anapico APSIN12G Signal Generator
- #8103: Driver: AR DC7441A Coupler
- #8110: Ability to control the ALC mode of the Agilent N5183A
- #8119: HP3478A as Multimeter is selecting DC voltage instead of AC voltage
- #8122: Driver: Werlatone C2630-10
- #8132: Ability to control the Pulse limiter and the Pre-selector of the PMM 9010F
- #8135: Configurable device driver write an empty 'Get ID' query and is also trying to read a response
- #8142: Driver: Bonn BSA series interlock
- #8143: RadiSense V Field sensor new firmware implementation
- #8150: Time-out and unlogic measurement values while using multiple PMM EP-601 simultaneously
- #8161: CI calibration is not reaching the desired test level
- #8166: LumiLoop LS Probe TCPIP controlled CI Serial Number raised an error
- #8187: Communication problems with TDEMI 1G, selecting the input
- #8189: Logarithmic step frequency of 0.5% is not used in a CI Calibration
- #8375: 0dBm input limit of amplifier is reached, limited to 4Vrms
- #8376: Signal generator cannot get low enough
- #8385: RIGOL DSA815 is not working because USB TMC driver from NI VISA 17.0 is not working correctly
RadiMation version 2016.2.9
- #2558: Driver RadiLink as cable
- #3534: Driver: Agilent 34980A as an oscilloscope
- #4063: Driver Milmega AS0860-15/25 RF usb controlled
- #4076: RadiSense III not working
- #4213: Driver EMControl Antenna tower
- #4259: Driver: Configurable Field Probe doesn't work with HI6005
- #4809: Driver: Hameg HMS3010 Spectrum Analyser
- #6142: Driver: emtest UCS500N: Telecom line surge: 2 line / 4 line
- #6356: Driver: FCC Bulk Current Injection probes
- #6407: Driver: IFI SMX-500 Amplifier
- #6803: R&S ESU 40: Error -222: Data out of range FREQ:CW 4500 000 000 HZ
- #6870: Driver HP 3458A Multimeter as AD Converter
- #6970: Problems and overrange detected during CI Calibration
- #7181: Driver: euro EMC RSC
- #7244: Detect the 'Not referenced' state of the Maturo MCU controller
- #7324: Prana MT400 Amplifier still in operate
- #7325: Prana MT400 Amplifier not always to RF-ON
- #7477: Driver: Bonn elektronik BLMA1060-50 Amplifier
- #7604: Driver: BONN BLWA 0810-200/100 LAN
- #7664: Unknown error: -1073807343
- #7705: R&S SMT 06 Pulse modulation sometimes show a wrong pulse width setting
- #7742: Amplifier Linearity test is not working when a variable testlevel is used during the calibration
- #7771: R&S ESI as powermeter is measuring too fast
- #7784: Preamplifier of Rigol DSA815 is not working in the GTEM test
- #7814: Teseq PCJ 9201B: Unknown Device Driver
- #7816: Driver Rohde & Schwarz BBA150 powermeter(s)
- #7837: Driver: DARE!! Instruments BCI1004A
- #7839: Settings to select 3 axes besides isotropic for Narda EMC 300 field probe
- #7846: Ok button is not working caused by powermeter settings panel
- #7850: RadiCentre 1 with RSS1006A controlled by RS232 is not working correctly
- #7861: RadiSense is not working
- #7862: Selecting an invalid baudrate doesn't raise a specific error message
- #7864: Previous environmentaldata is not always remembered
- #7865: Agilent SG 33120A is not turning on the output
- #7871: Driver Rigol DSG830
- #7872: Preamplifier on DSA832 cannot be activated during SB GTEM test
- #7875: Driver CWS 500N3
- #7891: Driver: Antenna ETS-LINDGREN GTEM 5317
- #7895: TDEMI Device Not connected
- #7900: Maturo MCU has slow communication
- #7910: Extend PMM9010 driver to allow selection of CISPR-Average or (old-)Average as Average detector
- #7914: Clicking on a peak in the emission frequency graph very often moves the frequency of the peak
- #7920: Selection of DC Coupling on R&S ESW8 Input 2 is not possible
- #7923: Driver Agilent 3499A Switch Matrix
- #7931: Catch BONN BSA 0110-100 EXECUTION_RESULT errors
- #7933: Optimize communication with RadiGen
- #7938: Signal generator VI modulation frequency is incorrectly set
- #7941: Maturo NCD controller Device Not Connected
- #7942: How to configure R&S BBA150 amplifier communication settings
- #7943: 1000W1000 input invalid correction file
- #7944: Ability to set a signal generator frequency offset for AnalyzerAsPowerMeterDecorator
- #7952: Driver: R&S FSH 8 as readout unit for field probe
- #7960: Receiver measurement from 500 kHz - 1800 kHz on the ESI results in a timeout
- #7968: Radimation is working in "EFT Multiband" only. The test in "EFT" is not performed
- #7972: RGN Data out of range error during initialization
- #7973: Control of RadiSense III raises the error: E3 Invalid Command
- #7979: Missing test equipment in the Report Generator
- #7982: Ability to define a power offset for the RPR RadiPower
- #7984: RadiCentre controlled devices are not setting the RadiCentre back to local
- #7997: R&S URV35 Level Meter as AD Converter
- #8002: Driver: ETS-Lindgren HI-6006 Field Sensor
- #8010: Driver DARE!! Instruments BCI1004A Coupler
- #8012: Environmental data window unable to press OK
- #8013: Agilent Technologies E4432B: Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
- #8019: Compression EUT Calibration table export same for every compressionPoint
- #8026: Driver: Hameg HMS3010 as Powermeter
- #8153: Provide C header file for Device Driver API, to make importing in ATEasy software possible
- #8164: Provide C header file for Device Driver API, to make importing in ETSI Power Meter 300328
RadiMation version 2016.2.8
- #4497: Calculation of the number of frequency steps generates an unhandled exception
- #6690: Driver: Bonn Elektronik BTA series amplifiers
- #7039: Limitlines color issue
- #7128: Index was outside the bounds of the array error 536879965
- #7179: Deadlock Unknown SetValueID
- #7182: Reopening Surge TSF file gives error
- #7257: Change Basic small controlling window for FieldSensor
- #7439: Graph from Burst Measurement disappears
- #7444: Opening VI PowerMeter takes long time file loading
- #7473: Error description unavailable
- #7519: Error after saving EUT
- #7643: RadiLog crash when ":" is in subject text.
- #7707: Graph Visibility states not remembered
- #7711: Skip report generator tests in template functionality is not working.
- #7840: Deadlock when Report Generating a CE MB test
- #7841: Unable to overwrite normal.dotm during Report generation
- #7857: Report generator code is changing the visibility states settings for the test results
- #7874: Repeating a sweep in a stored file (small bandwidth)
- #7876: DC Coupling Test Initialization Error
- #7880: Amplifier Linearity test
- #7899: How to retrieve the VBW and RBW of the second band in the Report generator
- #7928: Driver TTi CPX 400 DP as AD Converter
- #7959: Re-measuring peaks gives NI hibernation
- #7976: Powersensor (ID1576/ID1497): Device Not Connected.
- #8006: StartEnd deleteblock genereates a newline
- #8182: GraphControlls stays disabled
- #8352: New lng files with new DareLang.dll with old RadiMation causes glitches: Â
RadiMation version 2016.2.7
- #3965: Is not possible to choose between EXT-AC and EXT-DC using the siggen HP8648A
- #5758: Driver Monitor OSD dAV-C(r)-SD/HD
- #6111: R&S AFG device check seems to be always successful
- #6557: Update the CD Start menu for 2016.2
- #7287: Possibility to specify the Attenuation in the generic Powermeter-Analyser device driver
- #7740: Amplifier Linearity in Net power calibration method
- #7776: Driver All other ETS-Lindgren 8100-series amplifiers
- #7805: Deadlock when reviewing a RE Burst test results
- #7809: emtest CWS500N2.2 powermeters are not correct
- #7810: HP85xx-series has timeout after DONE query
- #7813: Clicking Full Span gives error and crash radimation
- #7815: Rohde & Schwarz ESW8 returns Device not connected
- #7817: Driver: PMM SB-10
- #7821: Driver: UCS500Mx
- #7838: Driver R&S ESR as powermeter
- #7851: Unknown GetValueID error when using a 1 ohm resistor
- #7855: Opening older test results triggers errors of wrong correction files
- #7856: Null reference exception during selection of EUT file, caused by ProposedSaveEUTFilename
- #7858: Opening older test results shows an error of an incorrect number of columns in the correction file
RadiMation version 2016.2.6
- #3168: Is amplifier protection working in a multiband immunity test
- #3517: Radiated Immunity: Level is going too high
- #4397: Forward power protection file for an Amplifier is ignored if power is already limited
- #4586: Amplifier limit completely ignored
- #5099: Too much data point with ESU8 and out of memory errors
- #5767: ESR7 is an unknown device driver
- #5952: Error ESRP 3 Receiver DC: More points received from the receiver/analyser then calculated
- #6853: Decrease testlevel is not available anymore as a shortcut key action
- #6855: Limitation of a Multiband Immunity test on the current is levelling just above the limit
- #7372: Driver: LSProbe from LumiLoop GmbH
- #7459: RadiPower driver doesn't support POWER? in mode 3
- #7800: Frequency span is not always correctly selected on the Advantest TR4172
- #7801: Only 51 peaks are detected
RadiMation version 2016.2.5
- #3489: Add support for IEC 61000-4-11: Voltage dips and Interrupts for AC mains
- #6109: Incorrect AD measurement after AD channel settings are unexpectedly changed
- #6127: Older TSF file with minimum performance limit is not working anymore and is crashing the software
- #6128: Small dips in negative singleband Emission results
- #6172: Add support for IEC 61000-4-29: Voltage dips and Interrupts on DC input power
- #7621: Exporting Report Generator using different extentions for template as the output, causing error cannot open file
- #7635: Error access to the path (..) is denied after Network Analyser Calibraton
- #7650: Voltage test level Voltage measurement (Powermeter) is not measured
- #7712: No easy manner to activate or deactivate all available Monitoring input channels
- #7770: Removing Test level from RI MB is closing the test and also gives error
- #7774: Correction of resistor is not used in magnetic field measurement
- #7788: Environmental data window can be shown behind mainwindow
RadiMation version 2016.2.4
- #4132: Minimum performance with pulse modulation not working correctly
- #6301: Preamplifier setting is not visible anymore in the CE MB TSF window
- #7428: Load XML error at RadiMation Startup
- #7640: Crash during startup due to newer CUSTOMIZ.XML
- #7658: Ability to physically us one powermeter multiple times in RadiMation to measure forward and reflected power
- #7714: Unlogic that the (activated) Monitoring input channels are used during Radiated Emission
- #7758: Error is raised that columns contains 3 columns, even if only 2 columns are present
- #7765: Error the maximum recursive read count has been reached during startup
RadiMation version 2016.2.3
- #2079: Usage of Amplifier protection is not clear if correction file has wrong columns
- #2631: Changing the minimum attenuation value argument in the device driver is changing the set attenuation
- #4209: No frequency verification on correction file
- #4380: CI multiband: crash during changing the band
- #5071: N9010A is not recognized anymore Unknown system error
- #5505: Rounding issues of Correction values (COR) when copied to clipboard
- #5515: Different measurement results with Singleband and Multiband test for Fixed Power method
- #5647: Correction file doesn't allow logarithmic interpolation of the value
- #6101: Disable all menu and editable items of which an engineer has no rights
- #6736: Correction is remembered in Virtual Instrument Powermeter when the correction file is detached again
- #6984: Infinite regulation when amplifier is in noize region
- #6987: RadiLog in 64 bits
- #6996: Peak numbering for emmission measurements are not shown and can't be sorted
- #7015: Radiated Immunity variable power closed loop with current sensor is endless regulating at first point
- #7159: RadiLog crashes with out of memory during a big test
- #7161: 7th point in RI calibration
- #7288: RadiLog slow with big description
- #7393: 'Output boxes' is shown as 'Unknown device driver types' in the 'Devices' menu
- #7445: Reflected powermeter measurements are not corrected
- #7533: Multiband Ok button of 'Continue automatic mode settings' is disabled
- #7555: Duplicate other test description menu in the graphs menu
- #7579: Copying the information of the EUT Monitoring grid to clipboard causes crash
- #7594: Radilog Deleted log when closing test
- #7595: RadiLog cleared within sequence
- #7569: Usefull RadiLog default description when sending an error report
- #7597: RadiLog Error Report disappearing window after sending log
- #7617: Cancelling the closing of the VI Fieldsensor results in a not working window
- #7618: Export of time-graph doesn't export all the data
- #7627: Endless regulation at frequency point during RI Fixed power test
- #7649: ReportGenerator to much capital letters
- #7660: Adjusted Fieldstrength units are not used in the scaling of the VI graphs
- #7663: CONFDVDR deadlock when Access to the path (..) is denied error is raised
- #7688: Correction data is not correctly determined from unsorted correction file
- #7691: Exporting graph to LLF doesnt show the in graph
- #7692: Copying the EUT Monitoring table to the clipboard causes a crash
- #7719: Exporting AD channels
- #7725: Multiple cosmetic changes to prevent controls from being hidden when window is resized
- #7726: Unicode: EUT files with chinese characters in the filename are not loaded correctly
- #7729: RadiLog doesn't show full binary data strings
- #7734: Report Generator code Step Frequency for ConEmi absorbtion clamp
- #7735: Unicode: INI files in unicode
- #7748: Unicode: Test-Sites
RadiMation version 2016.2.2
- #1688: Cannot save multiband test
- #3398: Test on hold when opening RE Multiband file
- #4074: Optimize angle is not measuring every area
- #4155: Device specific parameters are not retrieved when a device driver is created
- #4714: Cable loss correction applied to the Cable antenna Preamp is incorrect
- #4771: Adding cable with default port type value is not correct
- #4800: Comparing test data and zooming graphs in Multiband is not working
- #4823: CORrection factor current probe is not taken into account
- #4855: Possibility to directly open device driver TYPE window and TAB by just one click
- #4892: RM crash during RPR2006P Free mode when test equipment is opened
- #5222: Add a Virtual Instrument for the Amplifier
- #5223: Add a Virtual Instrument for the Signal generator
- #5270: Peak conservation setting is ignored for Singleband Radiated Immunity
- #5368: Graph data is not updated
- #5550: Add an 'Configure...' menu entry in all the sub-menus of the Devices menu
- #5565: Opening the virtual powermeter window shows a corrupt file error
- #6130: Device driver: emtest VCS 500
- #6228: Cable correction is not correctly taken into account during the Current Probe test
- #6421: Multiband graph is not exporting vertical and/or horizontal polarization graph
- #6667: Virtual Instruments should be able to collapse to a 'mini' mode that only shows the measurement value
- #6703: Driver: em test PFS 500
- #6704: Driver: em test MV2616
- #6705: Driver: emtest UCS500N5: voltage dips and interrupts support
- #6745: Include a 'Clear' button on the VI Fieldstrength sensor to clear the (time-)graphs
- #6746: Lower and upper value of the analog meter on the VI should be autoranging
- #6747: Show the 'table' tab for the time-graph in a virtual instrument
- #6749: Time graph in Virtual Instrument is using the wrong date
- #6750: Time graph of a Virtual Instrument should have a minimum time range of 30 seconds
- #7040: Marconi signal generator doesn't respond on *STB?
- #7065: A MB emission test shows a 'Fail', even if all emissions are below the limit
- #7102: Backwards sweeping is not correctly handled
- #7151: VDI: ProgressBar starts at 99%
- #7202: Longer time till sleep mode Narda EP600/EP601
- #7205: Default settings of Multiband EFT is not logical
- #7206: Default settings of Multiband Burst is not logical
- #7210: emtest PFS 500N Not all bytes are written
- #7213: Sequence are shuffled
- #7230: VIBase not always (dis)connecting
- #7231: Add suggested values
- #7234: Unit window showing example of setted settings.
- #7235: Clear Graph button in the VIBase is not correctly implemented.
- #7239: Unable to clear graph in VI windows while trigger is set to auto.
- #7250: Unit settings example is not correct with a precision of 0
- #7251: Unit settings applied to AnalogMeter control before init
- #7276: Unit settings are applied on fieldsensor not on the ctlAnalogDigitalMeter control itself.
- #7307: Error messages in the VI Powermeter are not shown
- #7327: Not controllable EFT and Surge device drivers should raise an error, early at the automated test
- #7328: Multiband EFT Test is in a continuous loop, when an error is raised
- #7335: Determined Forward power step during amplifier linearity is 100000 dB
- #7360: Calculated graph is recalculated 6x when an additional non-relevant graph is shown
- #7363: VIBase not always (dis)connecting
- #7364: 'Clear' button is hidden when the VI window is resized when the device is disconnected
- #7366: Resizing of 'Logging' tab of VI Powermeter is not done when another tab is active
- #7367: Tabs on the VI Powermeter should be hidden when the size of the window becomes too small
- #7368: Hide the analog meter if it becomes too small
- #7369: Improvements for the VI Turntable window
- #7370: Allow smaller size of VI Antenna tower
- #7371: A VI window should remember it's location and size
- #7373: RadiFree warnings
- #7374: Location and size of the window is not remembered if the RadiMation main window is closed with windows open
- #7375: Settings of the VI Signal generator are not set in the signal generator after a connect
- #7376: Clear button of a VI should also be enabled when the device is disconnected
- #7377: Clear button should be pressed automatically when the VI window is closed
- #7378: Only show the test initialization window if it contains more than 1 item
- #7380: Auto-Show and Auto-Connect for VI devices
- #7388: Resizing of the contents of the VI Powermeter window is incorrect
- #7389: Virtual Instrument window of the Virtual signal generator is always showing disabled controls
- #7391: Improve the showing of the 'Devices' menu
- #7396: RadiMation crashes during start with open automatically connecting VI windows
- #7410: Saving a test equiment with changing just 1 char to uppercase seems to overwrite the existing test equipment
- #7413: Unit Volts per meter shows only V
- #7417: Validation documentation of RadiMation
- #7429: Correction of Monitoring Input powermeter is also applied to the used (forward) powermeter during the test
- #7442: Invisible Clear Button
- #7443: Visible progress bar
- #7446: Reflected powermeter measurements data is incorrectly shown
- #7452: Improve the showing of the "Test-Site Menu"' menu
- #7453: Device menu also contains an Add Device button
- #7458: Address Information will pause a running test
- #7464: Name the log file the same as the subject description instead of always Last error report
- #7470: VI Signal Generator Carrier ON and OFF control has incorrect triggering
- #7507: Graphs are not drawn when 'Ramp' method is used in MB Immunity
- #7512: Virtual burst powermeter doesn't work anymore in RadiMation Free 'Burst' mode
- #7529: New testsites are shuffled in the Test-Sites list
- #7598: Error report, customer information is not remembered
- #6218: TSF description inside a SEQuence is changed to No Description
- #6634: Project: Voltage dips and interrupts
- #7004: Pasting large data (19000 rows) into a COR file is crashing RadiMation
- #7018: System error is not included in the Report Error
- #7026: Closing the adding of a short cut key is still adding the entry
- #7027: Save as test equipment buttons are incorrectly alligned
- #7029: RS232 communication method available for the Keysight N9038A while the device does not support it
- #7060: Changing a value in the Advanced Options grid, resizes the columns to very small
- #7121: The attenuation in MB Emission shows: Auto (100 dB)
- #7122: Layout of CE Multiband TSF is strange
- #7150: VDI: ReducedVoltageTime not marked in seconds
- #7152: VDI: Adding EMtest VDI driver.
- #7153: VDI: Remove workaround in device driver Keytek
- #7154: VDI: Repeat count
- #7155: VDI: Repetition time is not passed to the driver yet.
- #7157: VDI: Only show available line couplings.
- #7158: VDI: Debug EMTest UCS500N VDI driver on the device itself until it works.
- #7160: VDI: LineCoupling ignored error when starting test
- #7162: A strange symbol as digit seperator is not used in the interpretation of a string
- #7164: VDI: Phase Angles
- #7165: Repetition count
- #7166: SurgeMB phase angle cannot be selected
- #7172: VDI: ReducedVoltageTime not marked in seconds
- #7186: VDI: Reopening VDI with multiple bands shows unable to start error.
- #7527: Include ADVANCED.INI and TUNING.INI in an error report
- #7530: Selecting 'AD converter selected in testsite' as monitoring input device is default selecting 'nothing' instead of channel 1 resulting that nothing will be measured
- #7540: Channel numbers are all default set to 0
RadiMation version 2016.1.13
- #6304: Reference level should be requested to ensure a correct calculation of the measurement value
- #7437: R&S FSEK 30: Function not available;BAND:MODE:FFT OFF
- #7468: Quasi peak measurement of Analyser sometimes has a difference
- #7634: R&S FSEK 30: Function not available: FFT OFF
- #7786: Regular expression of RFS2006B antenna tower is incorrect
- #7787: Driver Vectawave VBA230-22 and VBA1000-150
- #7789: Advantest TR4172 Not all bytes are written to the GPIB-Board within the timeout period
RadiMation version 2016.1.12
- #1784: Agilent E4416A/E4417A (EPM-P series) should have option to measure Peak power
- #5629: Include option to 'Run Radimat.exe' after Device Drivers setup program
- #7080: Driver: EM test CWS 500N2.2
- #7099: Changing Powermeter advanced Measure setting is not enabling other settings when only the value is changed
- #7301: Driver Messtechnik Motion detection system
- #7475: Extend Field sensor device driver configuration with advanced Monitoring measurement settings
- #7476: Wrong measurements at first frequency point of the test
- #7615: Does the driver of the Power meter E4417E performs reading of the peak value?
- #7641: Measurements take a long time with the Advanced ESU 40 / FSV as a powermeter
- #7659: Agilent N5182A error the measurement device does not support this functionality
- #7666: Driver R&S EZ17 current probe
- #7668: Driver: Schaffner/TESEQ CDN S150
- #7669: Driver Schaffner/TESEQ CDN USB/p
- #7672: Driver: MEB CDN S25
- #7673: Driver: MEB CDN S1/50
- #7674: Driver MEB CDN MEB KEMZ801
- #7676: Driver: Switch matrix HP3488A
- #7677: Driver: NRP8SN
- #7678: Driver: Directional Coupler RFPA RFC801000 -40-150
- #7679: Driver: Directional Coupler RLC CHP-1040-D-40-40-FF
- #7681: Driver CDN Schaffner USB/c
- #7683: Driver CDN Teseq M116
- #7684: Driver: NRP8 Power meter
- #7698: EM Powermeter unable to pass the checkdevice.
- #7702: Driver: ETS-Lindgren's 8100-045 RF Power Amplifier
- #7703: Driver: Werlatone C10762 Coupler
- #7704: How to use a manual Turn Table during Multiband Emission?
- #7709: Sensata Olimex SENT (Configurable AD Converter) Timeout before operation completed
- #7710: Spectrum Analyser (ID1465) Input 2 (LAN): SPecific System Error: -410, "Query interrupted"
- #7730: False graph of result of N9000-series measurement: High emissions
- #7739: Agilent E4417A Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
- #7747: EMTest UCS500N + Phase 3 coupler Error
- #7749: SetEndOfString is not used
- #7762: Ability to use the Configurable AD Converter for PMX
- #7772: The measure time is not always correctly set when the receiver is used as a powermeter
RadiMation version 2016.1.11
- #4272: Wrong values tuned frequency range HP85685A Preselector
- #7008: Reflected power too high
- #7082: CE test 20V problem
- #7279: End of Surge test is not correctly detected on a Teseq NSG3040
- #7461: Unable to use formula option in AD converter
- #7485: Driver Signal Generator Keysight 33522B
- #7515: SRQ errors are generated using Tektronix TDS5034B
- #7542: Driver Amplifier IFI S41-250
- #7624: Driver Keysight Amplifier N4985A
- #7631: Agilent Technologies N9038A Scanning Receiver: Device is not aligned error
- #7638: Maximum selectable RBW for the Analyser As Powermeter settings is 50 kHz
- #7642: Agilent N9038A set RBW raised error Data out of range; the value 0 was clipped to the minimum value of 10
- #7651: Wrong frequency range Teseq CBA 1G-1000
- #7654: Configurable Amplifier custom frequency range is not retained
- #7693: Device driver configuration of the RSS1006A (CTR1001S) field sensor
- #7699: Re-enabling the selectioning of peak markings
- #7763: How to launch programs?
RadiMation version 2016.1.10
- #2533: Power conservation is not clearly described in the user-manual
- #3917: Nonexistent peak and wrong final measurement with PMM during conducted emission multiband tests
- #4550: Driver: EM-Test Signal generator CWS 500
- #4596: Problem with PMM in latest version
- #4821: Driver Tektronix 3000 for fixed voltage test
- #5989: Driver: emtest CWS500N for IEC61000-4-6
- #6328: Driver FSV-3 as powermeter
- #6383: Error -222 Data out of range;INP:ATT 50 DB while deinitializing a R&S ESL 6
- #6767: Too much reflected power in combination with the RadiField
- #6955: Error too much reflected power due to RadiField reflected power value
- #7030: Driver: CWS500N2 EMTEST
- #7107: Incorrect LimitLine values
- #7232: R&S ESI26: Data out of range: 1 Hz RBW during powermeasurement
- #7323: Prana MT400 Not all bytes are written to the GPIB-Board within the timeout period
- #7463: Test duration takes a lot of time as compared with a old software used before
- #7505: Frankonia FC 06 Turntable Error -33072 (Invalid target position)
- #7508: End frequency is not correctly stored in an attenuation/gain system calibration
- #7524: Driver NOVOTRONIK GTS5611 switch matrix
- #7525: Driver NOVOTRONIK GTS5601 switch matrix
- #7553: How to configure default graph log or linear scaling?
- #7554: Driver Advanced settings for ESU 40 as a powermeter
- #7592: RadiMation does not trigger a GetCurrentStatus after Operate and PowerOff
- #7599: Driver: AR FL7218 Field Probe
- #7601: RadiPower RPR2006 powermeter Windows device drivers
- #7602: Bonn Testsystem
- #7605: GPIB-Board is not controller in charge (CIC) GPIB: ECIC
- #7607: Shifted Report Generator table
- #7620: PI EFT singleband Report generator codes empty
- #7648: Missing keywords for EUT calibration Harmonics
- #7686: Wrong title above emission plots
- #7687: Progress bar in PI MB tests is not visible after second sequence
RadiMation version 2016.1.9
- #1828: Additional total max hold graph window
- #1957: Wrong message when no impedance file is selected
- #3001: Manual is missing information on how the corrections (and the to be used columns) should be used
- #3444: LISN ESU User port lan device
- #4975: Sorting of table frequency data in the Report is incorrect
- #5815: Driver Agilent N1911A powermeter
- #5863: Error File is not found: %s when opening TSF or after crash
- #5994: Test initialization failed for Agilent N5181A-506 with Pulse Modulation option
- #6177: CARAD EUT Controller driver raises Ethernet not connected errors
- #6420: Exported RAW data is still showing unit information
- #6752: The Device Specific value 'Power' of the powermeter should be renamed to 'Uncorrected Power'
- #6902: Keywords TEST SITE EMAIL ADDRESS and CLIENT EMAIL ADDRESS are not working anymore
- #6933: Driver Luthi MDS 20 Absorbing Clamp
- #6934: Driver EMCO 3158 Antenna
- #6935: Driver CBL 6144 antenna
- #6936: Driver ARA DRG 118a Antenna
- #6944: Driver Holaday HI4422 FieldProbe
- #6951: Driver Schaffner NSG 2070
- #6961: Description for this error is not available is shown during startup
- #6964: Ability to have Start and Stop Dwelltime events for the NI 6218 switch matrix
- #6993: RadiGen RGN6000B Setting the output level raised an error
- #7010: Use a NI USB6501 to switch between forward and reflected power
- #7024: Problem solving for the test setup of a Conducted Immunity Mil Std Calibration
- #7025: Driver Rohde & Schwarz ESW26
- #7197: Driver Generic National Instruments Output Switch
- #7275: Switching matrix OSP 120. Relay K11 on slot 3 doesn't switch
- #7291: RadiGen RGN6000B HF Returns error: -222 Data out of range
- #7298: TCPIP Communication is not working correctly for the TDEMI
- #7304: TCPIP controlled TDEMI Powermeter raises a crossthread error message
- #7311: Driver Aaronia Spectran HF-60100 V4 X
- #7314: Insert additional frequencies
- #7340: Driver AE Techron 7224
- #7341: Driver OSR C21A8
- #7342: Driver TESEQ CIP 8136
- #7343: Driver Rohde & Schwarz ESW8
- #7345: Driver Agilent 87405A pre-amplifier
- #7346: Driver Agilent 34401A
- #7348: Driver Agilent 54831B as oscilloscope
- #7349: Driver Agilent 34401A
- #7352: Driver Antenna Schwarzbeck BBHA 9120J
- #7353: Driver Antenna Schwarzbeck STLP 9128ES
- #7354: Driver Directional Coupler werlatone C7354
- #7356: Driver AR 500W1000B
- #7379: R&S NRP only channel a is working
- #7381: R&S ESL6: Several GPIB communication problems
- #7397: RadiField RFS1006B Returns Error 521. Driver 3 current out of range
- #7403: Communication with plugin cards is lost
- #7433: Not all data is recorded in RE GTEM
- #7466: RadiField RFS1006B Returns Error 560. Communication amplifiers failed
- #7478: EFT/Surge and VDI Report Generator keywords overview
- #7480: Question regarding R&S IMS device drivers
- #7483: Update the RadiMation software requirements
- #7486: RSW1024S Interlock: Not all bytes are written to the GPIB-Boadr within the timeout period
- #7487: RadiField RFS1006B Returns Error 526. time out error GPIB
- #7488: RadiField RFS1006B Returns Error 1087. Signal power went to high (-6dB) during power delivery test
- #7493: RadiField RFS1006B Disconnecting error: No amplifier connected
- #7494: Kalmus amplifiers cannot be controlled. GPIB: No listener on the bus
- #7495: RadiField RFS1006B Power off after disconnecting device
- #7502: Extend the IDocument interface to also return an unique IDataIdentifier
- #7503: Change the implementation of IGraphElement::DataIdentifier to also use the IDataIdentifier of the data document as the parent IDataIdentifier
- #7504: List of available graphs should use the IDataIdentifier of the graph element
- #7510: SetMicroSecondsDelay is ignored/not used when set from the 'AfterStreamConnectConfiguration'
- #7516: NI DAQ Error 6009 Unable to keep up with the hardware acquisition
- #7521: How can the complete graph data of the polar plot be exported as table data?
- #7534: SMR40 driver slowed down in communication
- #7538: How to disable the power delivery test?
- #7539: Driver Antenna BBA 9106
- #7541: Driver PowerSensor Agilent N1911A
- #7543: Driver Antenna SBA 9113
- #7547: The used and installed version of the NI GPIB Library should be logged in RadiLog
- #7548: Setting the VISA communication setting to the Visa-ID is automatically being changed to RS-232
- #7550: Driver Broadband Preamplifier Schwarzbeck BBV 9743
- #7556: Extend the license that the user agrees that RadiLog and other reported gathered data being send might contain confidential content
- #7558: Driver Keysight EXG N5173B signal generator
- #7562: Driver SG6000 Signal Generator
- #7564: Driver Measuring amplifier B&K 2636 Analog, 1 channel (via GPIB now)
- #7570: Driver Directional Coupler Warlatone C9475
- #7571: Driver Teseq CDN M016S
- #7572: Driver Teseq CDN S501AS
- #7573: Driver CDN S751AS
- #7574: Driver Werlatone C5982 Dual Directional Coupler
- #7577: Easy merge of multiple EUT Attenuation/Gain corrections to one correction
- #7583: ETS-Lindgren HI-6053 error No match was found in the specified regular expression
- #7584: Driver Generic NI DAQ mx AD Converter device driver
- #7587: How to configure a limitation on power during a DO-160G/ED-14G BCI test?
RadiMation version 2016.1.8
- #4514: Support the +10 dBm output of the RadiGen
- #5705: Device driver Baudrate and terminator character settings are not used
- #6427: Please include in the manual that the graph trace description is a valid Report Generator keyword
- #6800: Exported AD Limit does not have the same color in the report
- #7101: Pulsed Immunity ESD is not removing selected tab
- #7195: Driver Amplifier VBA1000-275
- #7248: Testing a frequency above 1 GHz takes much more time than the configured dwelltime
- #7313: Reopening test files gives error: Object variable or With block variable not set
- #7426: Reflected powermeter is required when performing a Multiband fixed power test at Forward powermeter level
- #7450: Example of an emission measurement
- #7451: RadiLog search function does not always match
- #7460: RS232 communication settings are not updated
- #7469: Logarithmic step measurement using the R&S ESCS causes a crash
- #7491: Measurement with N9038A stops at 400 MHz.
- #7517: R&S ESCS 30: Not all bytes are written to the GPIB-BOARD GPIB:EABO
- #7531: Configurable AD Converter is using input range min max as multiplier
- #7546: Some PC's suddenly raise NI GPIB hibernation errors. A PC restart is then needed
- #7552: TCPIP controlled EUT monitoring of an Amplifier
RadiMation version 2016.1.7
- #4026: 10dB Min Attenuation is not switched OFF with the TDEMI
- #4030: TDEMI controlled LISNs
- #4674: Device driver system is currently not usable
- #4828: Guide how to configure and use RG templates
- #5600: RadiMation crash after Gauss TDEMI device driver check
- #5886: Driver R&S SMR20 Signal Generator (with internal pulse modulation)
- #6252: GAUSS Instruments TDEMI device firmware update now causes a timeout error after reset
- #6382: EM TEST UCS 500 Surge generators not possible to configure the GPIB address
- #6622: Driver: Different models for the Gaus Instruments TDEMI
- #6630: Add RadiLog messages to the DeviceDriverBase class
- #6647: RadiSense 6 fieldprobe connected by Radicentre 1 is raising an error
- #6791: Driver RadiField 2000 series as EM Field generators
- #6893: Add events when starting tests
- #6910: Driver: TDEMI X6 Spectrum Analyser
- #7037: Aplying modulation out of dwell time period gives odd peaks
- #7038: Disabled modulation at frequency steps
- #7063: Driver: Gauss TDEMI X
- #7110: Closing of the virtual Field sensor measurement window
- #7118: EM-Power 7002-006 powermeter Windows device drivers are not working
- #7137: Does Minimum performance take the minimum and maximum of every AD channel into account?
- #7184: Timeout on checkdevice TDEMI X3
- #7196: Driver: Amplifier Teseq CBA 3g-050
- #7209: emtest PFS500 SRQ line of the GPIB bus is raised by another uncontrolled device.
- #7224: AD convertor device trough MODBUS
- #7225: AD Convertor using OPC to connected with CAN USB convertor of PEAK with CANopen protocol
- #7290: RadiField RFS1006B Returns error: 574
- #7296: Cant add the HP8594E as real power meter to the EUT file after installing the latest drivers
- #7297: Check of a TDEMI is crashing if the device is not connected
- #7300: Driver Schwarzbeck NNBM 8126G seems to not work properly
- #7303: RadiField amplifier is not put into operate
- #7319: Driver: emtest CWS500N1.3
- #7336: EMTest EFT500
- #7382: Does RadiMation software use "Dwell for Combination of RF Immunity CW,AM,PM"
- #7385: Driver: EMTest TSS 500
- #7390: Connect button on the VI Amplifier window is not shown
- #7392: Selecting a VI from the Devices menu shows a new VI window, even if the VI is already open
- #7394: Update of the table of a graph, sets the selection to the first row again
- #7402: RadiPower RPR3006W questions
- #7405: Request Radimation driver for Rohde & Schwarz FSW-26 Signal Ananlyzer
- #7409: Software Protection Key could not be found
- #7447: Field Sensor FP5080 is returned unexpected values
RadiMation version 2016.1.6
- #4760: First band data seems to be lost with 10kHz tot 30 MHz Multiband test
- #5864: Preamplifier and reference setting have no effect for the ESL6
- #6086: Driver for the Delphin Technology Expert Key 100 box
- #6259: ALL RADIATED EMISSION TESTS is not replacing keywords of corresponding tests
- #6279: Readout of RadiPower in RadiMation Free raises overload at 0 dBm
- #6663: Provide same functionality as RadiMon
- #6687: Driver: Luthi MDS22
- #6708: No graph traces in the exported plots in the report for lower frequencies
- #6766: Measuring settings Lines/Neutral with LISN
- #6882: System requirements for RadiMation
- #6883: Using radiated immunity for shielding effectiveness
- #6915: Driver: Schwarzbeck BBA 9106 antenna
- #6916: Driver: Schwarzbeck MDS21 Absorbing clamp
- #6922: Driver: Teseq CBA 230M-80 amplifier
- #6923: Driver: Teseq PMU6003 Powermeter
- #6924: Driver: TESEQ DCP 0100A Directional Coupler
- #6925: Driver: Teseq KEMZ 801 Injection Clamp
- #6926: Driver: Prana MT440DC Amplifier
- #6927: Driver: Teseq NSG437 ESD generator
- #6941: Driver: Rohde & Schwarz NRVS
- #7006: Question: SMB 100A SignalGenerator modulation
- #7048: Selection of 'Neutral' LISN line is wrong when restarting last TSF
- #7062: Unexpected dips in measurements when rechecking peaks
- #7129: Corrupt Customized.xml will raise an error and crash RadiMation
- #7211: VDI Object reference error
- #7229: HP 8594E Spectrum analyser is not following signal generator.
- #7237: Report Generator graph only shows peak markers without the trace itself.
- #7243: Probe numbers are not shown anymore in the Field inputs dialog
- #7273: Behaviour of the ||EUT|DESCRIPTION|| Report Generator keyword
- #7280: Tabs of Device specific settings on the devices Virtual Instrument window are not shown
- #7282: Driver: Schaffner NSG 3025 BurstGenerator
- #7286: Vectawave amplifier is in endless loop, when an error is present
- #7317: RE MB build in preamplifier used at higher allowed frequency
- #7339: Driver: Agilent E4412
- #7350: Driver: AR 500W1000B
- #7359: Is the standard Din-EN 61000-4-6 supported through subsitution method?
- #7414: Device not connected errors for the PMM 7010 Low Input and Hi Input drivers
- #7430: No communication (device not connected) with Field Sensor FP5080
- #7431: RFS is not working and keeps powering off
- #7626: Final measurement of Average detector is lower than the average value of the prescan
- #7632: Not all emission tests are performed of the configured bands
RadiMation version 2016.1.5
- #5344: ESPI -222 Data out of range error
- #5434: Driver: Agilent N9038A, 44 GHz option
- #5480: Throw error or warning when 'Step Size clipped to nearest value allowed' for Agilent MXE N9038
- #5694: Driver Amplifiers Ophir 5225E / 5264E / 5274E
- #5786: Possibility to specify the 'auto-switch off' time of the PMM EP600-series probe
- #5956: Units change from dBm to W in the Power Meter Module does only change unit text
- #6273: Logarithmic step frequency for the Agilent N9038A
- #6310: Reference level of the N9038A is not set to the specified reference level in the TSF
- #6458: Several improvements and issues for the Agilent MXE EMI Receiver N9038A
- #6682: Driver Schwarzbeck MDS21
- #6683: Driver Schwarzbeck MDS22
- #6684: Driver Schwarzbeck LISN's
- #6685: Driver: Schwarzbeck VULB 9162
- #6688: Driver: Bonn Elektronik amplifier BSA 0125-25
- #6689: Driver Bonn Elektronik BSA series amplifiers
- #6718: Numbers on Analog scale of Virtual instrument should be updated when unit is changed
- #6792: Agilent N9038A: Non EMI average detector is change due to physcial constraints
- #6921: Driver: Agilent N5171B-506 + UNT
- #6940: Driver Bonn BSA 0122-20
- #7092: Longer time till sleep mode Narda EP600/EP601
- #7163: Errors connecting Lutron field probe
- #7170: Actual RH values no longer visible.
- #7173: Searching for possibility to download latest RadiMation version for driver release
- #7175: Wrong commands for Maturo ncd for antenna and turntable
- #7185: Unable to install the newest version, only HTTP and FTP are supported
- #7188: Advantest TR4172 No match was found in the specified regular expression
- #7194: Driver: Antenna Tower Inn-co GmbH MA4000
- #7208: Checksum error with the EMTEST CWS500N1.2
- #7217: Unexpected response from the Narda EP600 after filter setting command
- #7220: Driver: Vectawave VBA1000-1000
- #7238: Report generator text unexpected in bold.
- #7241: Sending an error report takes a long time (roughly 1 minute)
- #7246: Forward power and signal power graphs are not shown anymore in already performed tests
- #7302: Re-measuring peak values increases the measurement with 10 dB
RadiMation version 2016.1.4
- #423: Configuration of customer database is not retained
- #5211: Driver: Maturo NCD controller advanced error checking
- #5228: HP8594E GPIB error
- #5314: RadiMation database table and fields are sometimes not retained
- #5492: System error checking on HP 8562/8563 causes communication errors
- #5969: R&S ESU EMI receiver is only set to integer frequency values
- #6175: Driver: Thermo Scientific EMCPro-PLUS
- #6429: Peak Maximise settings change doesn't work
- #6795: Graphs and table overviews are mixed-up and not correctly displayed
- #6810: Driver: Lutron EMF-819 Fieldsensor
- #6839: Forward power column in the table of Amplifier linearity is not showing the first powerlevel
- #6871: Driver: Hameg HM8135
- #6957: Not possible to export a fixed field to a CAL file, errors is shown that modulation was used is shown while this is not the case
- #7032: GPIB communication is slower with newer drivers
- #7033: Unknown error message RadiField. Error 530
- #7045: Cannot find Modulation source in the currently active testsite
- #7052: Crash: CE MB Antenna Terminal measurements
- #7056: 1st correction file selection of antenna shows: 'Select a correction file'
- #7057: HP 8594E analyser as a power meter returns Not all bytes are written to the GPIB-Board
- #7061: Graphs and table of Amplifier linearity test is unlogical
- #7075: sorting of columns of the peak table is not working correctly
- #7076: Exporting field strength to calibration is not working, because a modulation is selected, even if 'No Modulation' is selected
- #7084: HP85xx-series: Incorrect measurement: Emission values up to 330 dBuV/m
- #7086: Setup downloads .NET 4.6 instead of .NET 4.6.1
- #7094: Bonn amplifier should be placed in REMOTE, also on GPIB
- #7105: Unlogical Red cross in AD Configuration dialog
- #7108: Selection of CapacitiveClamp on EMTest UCS500N not correct
- #7113: Polar graph is not drawn correctly, when the window has been maximized
- #7117: Driver TTi TGR2050 Synthesised RF Generator
- #7119: RadiMation does not start up after modifying global/standalone directory
- #7124: Object reference not set to an instance of an object: Frequency drawing of bands control
- #7127: Font of the legend on the polar plot is much smaller than on the frequency graph
- #7136: Unable to report error manually
- #7138: Issue with our home made 40 channel AD Converter
- #7141: AD Converter error during test initialization
- #7145: Output of multiple channels using LeCroy WaveSurfer Channel switch matrix driver during single band test
RadiMation version 2016.1.3
- #6311: Crash when maximizing the MB Emission test result window
- #6333: RadiMation crashes when maximizing the multi-band emissions results screen
- #6430: Radimation crash if radiated emission window resized during measurement
- #6686: Driver Luthi FT/FTC series absorbing clamps
- #6715: Run-time error 5 procedure call or argument is not valid in RADRESRC.DLL
- #6896: Error timeout with Maturo MCU controller
- #7017: SYST:ERR -222:Data out of range for RadiGen
- #7020: Limit lines are not shown automatically at the end of the test
- #7022: Maximum cable length is not included in the ||EUT|CABLE TABLE|| in the report
RadiMation version 2016.1.2
- #5587: Old LLF is not removed and not replaced with newly added LLF
- #6393: Graph is covering a rang and analyser is performing a test outside the specified bands
- #6464: Automatic search of highest peaks is changing graph shape
- #6466: Driver R&S FSL
- #6470: Driver R&S NRP2 powermeter
- #6518: FSU 3 error -200 Option ot available INP:PRES:STAT ON during test initialization
- #6723: Broadband disturbances are showed as peaks
- #6804: AD converter values of older tests are not correctly showed in latest versions
- #6865: Implement retry of Software Update used for RadiField amplifier firmware updating
- #6903: Add an additional 'Maximum cable length' field for a cable in the EUT
- #6904: Add a note field to a cable
- #6912: RadiLog icon disappears when pinned to the taskbar
- #6972: RadiLog is not able to write to temporary directory
- #6981: Setup program doesn't check if .NET framework 4.6.1 is installed
- #6985: Advantest TR4172 as powermeter is not correctly measuring
- #6986: RadiLog icon disappears when pinned to the taskbar
- #6988: R&S FSU: Not possible to select 50 MHz RBW
- #6991: How to determine the compression level using a constant output power test
- #6992: Software update will crash RadiMation when a connection error is found
- #6993: RGN Setting the output level raised an error
- #6994: R&S FSU undefined header -113 INP:TYPE INPUT1 error
- #6999: Time interval of table data from a multiband immunity test in the report skips rows if a large delay was present during the test
- #7005: Limitlines are not shown when old test results are opened
- #7011: RGN software update panel should be hidden
- #7012: Implement checking of system errors for RGN
- #7014: Report Generator can be used without a license
- #5988: Driver Teseq ITS6006 for IEC61000-4-3 & CISPR11 as Signal Generator
- #6556: Update the CD Start menu for 2016.1
- #6558: Update version and copyright years to 2016
- #6965: Add ability to return the RAW AD Converter value
- #6983: Empty tabs and no labels are shown after fresh installation
- #6998: Data table from Multiband Immunity in the report generator is always using time interval mode
- #7003: Device check of the R&S SMB100A is unsuccessful
Known Problems
R&S spectrum analysers/receivers communication problems
- Open the configuration window of RadiMation®
- Select the Device Drivers tab
- Select Receivers/Spectrum Analysers
- Select the R&S receiver
- Press Edit to open the device driver configuration window
- Press the Advanced button
- The GPIB configuration dialog of the R&S device driver will be shown
- Activate the Show advanced Settings checkbox
- The GPIB Configuration dialog will show a Wait time box
- Specify 3000 us in the Wait time box
Previous RadiMation® version raises a run-time error
Windows 8, Windows 7, XP, Vista and older are not supported
