Agilent Technologies 33250A
(Redirected from Agilent 33250A)
Jump to: navigation, search
The Agilent Technologies 33250A device driver is a Signal GeneratorModulation Source which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies 33250A:
The frequency range of the Agilent Technologies 33250A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent Technologies 33250A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent Technologies 33250A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
This low frequency signal generator can be used up to 80 MHz.
Documentation
The programmer manual can be found here
