Agilent Technologies E4423B
The Agilent Technologies E4423B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies E4423B:
The frequency range of the Agilent Technologies E4423B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Agilent Technologies E4423B.
Be careful changing these setting as RadiMation® is no longer able to verify if the Agilent Technologies E4423B is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
