Amplifier Research 100W1000M1A
The Amplifier Research 100W1000M1A device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 100W1000M1A:
The frequency range of the Amplifier Research 100W1000M1A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Amplifier Research 100W1000M1A.
Be careful changing these setting as RadiMation® is no longer able to verify if the Amplifier Research 100W1000M1A is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
- Google search: Amplifier Research 100W1000M1A
- Google image search: Amplifier Research 100W1000M1A
