Chapter 14
(Redirected from Before actions)
Jump to: navigation, search
   Menu.png Configuration
      Menu.png Engineers
         Menu.png Edit
Engineers
   Menu.png File
      Menu.png Change Engineer
      Menu.png Engineers
Test engineer settings
Adding an engineer
Deleting an engineer
Editing engineer settings
Password protection
  • The password is standard turned on for the default used test engineer 'Administrator'.
Rights
ScreenElementDescription.png Equipment Prevents unauthorized changes to test equipment configuration.
ScreenElementDescription.png Engineer Prevents unauthorized changes to test engineers configuration.
ScreenElementDescription.png TSF Files Prevents unauthorized changes to Test Setup Files (TSF) files.
ScreenElementDescription.png Limit Line Prevents unauthorized changes to Limit Line Files (LLF) files.
ScreenElementDescription.png Correction File Prevents unauthorized changes to correction files.
ScreenElementDescription.png General Configuration Prevents unauthorized changes to the general configuration.
Change password
Test Equipment
Adding test equipment
Deleting test equipment
Editing test equipment
Devices 1 & 2
Adding devices
Editing devices
Removing devices
Saving test equipment
Save As
Before Actions & After Actions
Before Action
Example
After Action
Default address information
      Menu.png Default Address Information
ScreenElementDescription.png Client Company The default company name for the client.
ScreenElementDescription.png Client Contact Person The default contact person for the client.
ScreenElementDescription.png Client Address The default address for the client.
ScreenElementDescription.png Client Zip Code The default zip code for the client.
ScreenElementDescription.png Client City The default city for the client.
ScreenElementDescription.png Client State The default state for the client.
ScreenElementDescription.png Client Country The default country for the client.
ScreenElementDescription.png Client Telephone Number The default telephone number for the client.
ScreenElementDescription.png Client Fax Number The default fax numberfor the client.
ScreenElementDescription.png Client Email Address The default e-mail address for the client.
ScreenElementDescription.png Manufacturer Company The default company name for the manufacturer.
ScreenElementDescription.png Manufacturer Contact Person The default contact person for the manufacturer.
ScreenElementDescription.png Manufacturer Address The default address for the manufacturer.
ScreenElementDescription.png Manufacturer Zip Code The default zip code for the manufacturer.
ScreenElementDescription.png Manufacturer City The default city for the manufacturer.
ScreenElementDescription.png Manufacturer State The default state for the manufacturer.
ScreenElementDescription.png Manufacturer Country The default country for the manufacturer.
ScreenElementDescription.png Manufacturer Telephone Number The default telephone number for the manufacturer.
ScreenElementDescription.png Manufacturer Fax Number The default fax number for the manufacturer.
ScreenElementDescription.png Manufacturer Email Address The default e-mail address for the manufacturer.
ScreenElementDescription.png Test Site Company The default company name for the test site.
ScreenElementDescription.png Test Site Contact Person The default contact person for the test site.
ScreenElementDescription.png Test Site Address The default address for the test site.
ScreenElementDescription.png Test Site Zip Code The default zip code for the test site.
ScreenElementDescription.png Test Site City The default city for the test site.
ScreenElementDescription.png Test Site State The default state for the test site.
ScreenElementDescription.png Test Site Country The default country for the test site.
ScreenElementDescription.png Test Site Telephone Number The default telephone number for the test site.
ScreenElementDescription.png Test Site Fax Number The default fax number for the test site.
ScreenElementDescription.png Test Site Email Address The default e-mail address for the test site.
ScreenElementDescription.png Ok Stores the modified information and closes the window.
ScreenElementDescription.png Cancel Discards the modified information and closes the window.
Advanced options
  1. Units
  2. Directories
  3. Device Drivers
  4. Graphs
  5. Database
  6. Language
  7. Measurement settings
  8. Product standards
  9. Basic standards
  10. Enhanced Status Window
1. Units configuration
  • Radiated Immunity
  • Conducted Immunity
  • Radiated Emission
  • Conducted Emission
  • Pulsed Immunity
  • Antenna Diagram
  • RadiCal
Changing unit settings
2. Directories configuration
Open the 'Directories' configuration screen
Go to the Directories tab.
Modifying the 'Device Driver Configuration Files' directory
Creating a new 'Device Driver Configuration Files' folder
Duplicating a 'Device Driver Configuration Files' folder
Change the path for a file type
3. Device Driver configuration
2. Through the 'Devices' tab.
Select a device driver type
Adding a new device driver
Editing a device driver
Removing a device driver
Confirm settings
Fixed information
ScreenElementDescription.png Brand Shows the brand of the device. This information can be changed/viewed in this cell and can be used in the report generator.
ScreenElementDescription.png Description Shows the description of the device. This information can be changed/viewed in this cell and can be used in the report generator. Changing the description does not result in losing the device in the test sites. The description is automatically updated in the test site information. If a report is generated from a test done prior to the description change the old description will be inserted.
ScreenElementDescription.png Device driver DLL Version Shows the exact version of the DLL in which the device driver is contained. This is a unique identifier that specifies the version of the device driver. The contents of this cell cannot be changed. (More information on this data cell is explained further below in the paragraph ‘Storing the driver version in the test file’.)
ScreenElementDescription.png Device drivers installation date Shows the date and time of the last update/installation of the device drivers. The contents of this cell cannot be changed. (More information on this data cell is explained further below in the paragraph ‘Storing the driver version in the test file’.)
ScreenElementDescription.png Device drivers versions Shows the version number of the last update/installation of the device drivers. The contents of this cell cannot be changed. (More information on this data cell is explained further below in the paragraph ‘Storing the driver version in the test file’.)
ScreenElementDescription.png Hardware version Shows the hardware version of the device. This information can be changed/viewed in this cell and can be used in the report generator.
ScreenElementDescription.png ID Shows the internally used ID of the device. This information can be changed/viewed in this cell and can be used in the report generator. The main function of this window is to link your measurement to your devices for easier reproduction.
ScreenElementDescription.png Serial number Shows the serial number of the device. This information can be changed/viewed in this cell and can be used in the report generator.
ScreenElementDescription.png Software version Shows the software version of the device. This information can be changed/viewed in this cell and can be used in the report generator.
ScreenElementDescription.png Type Shows the type of the device. This information can be changed/viewed in this cell and can be used in the report generator.
Additional options
ScreenElementDescription.png Add The ‘’’ ‘Add’ button’’’ can be used to add additional information items to the general device driver settings. The additional items will be shown in the list. Additional information items can be used to note the storage location, the location of the user manual, etc.
ScreenElementDescription.png Edit The ‘’’ ‘Edit’ button’’’ can be used to edit the information of a selected item. Information items that cannot be modified cannot be edited.
ScreenElementDescription.png Remove The ‘’’ ‘Remove’ button’’’ can be used to remove a selected information item from the list. Only additional information items can be removed. Fixed information items, as described previously, cannot be removed.
ScreenElementDescription.png Zero Interval When the Zero interval is activated, it is possible to specify a time period in minutes, in which a device does not need to be ‘re-zero-ed’. For accurate measurements it is necessary that Power Meters and Field Sensors are zero-ed. A zero operation generally takes several seconds to be completed and it may be valid for a few hours. To prevent that a device is ‘re-zero-ed’ during each test initialization, it is possible to set a zero interval in minutes. When a test is initialized and the device is already zero-ed within the specified zero interval, no zero will be performed at that time. Specifying and activating the zero interval can be a significantly reduce the time that is needed to initialize each test.
This setting is only available for power meter and field strength sensor devices.
ScreenElementDescription.png Calibration Expire Date This field can be used to set the date on which the device needs to be re-calibrated. Depending upon the setting in the configuration window, RadiMation® will use this date to give warnings/notifications on the recalibration. When you press the ‘calendar icon’ to the right of this field a small window will appear, allowing you to select the new date.
ScreenElementDescription.png Advanced The ‘’’ ‘Advanced’ button’’’ can be used to open the advanced menu of the device driver. In chapter 15, the paragraph ‘Device specific configuration’ will explain this menu for every device type. Please note that the configuration does not apply on the configurable or virtual drivers. Please view the paragraphs about ‘Configurable devices’ or ‘Virtual devices’ (also in chapter 15) for these devices.
ScreenElementDescription.png Check The ‘’’ ‘Check’ button’’’ can be used to check if the device is connected. This check is the same as the check that is performed during each test initialization. This check can be used to determine if the correct addressing is set, and whether communication with the device is possible. (This option is explained further below in the paragraph ‘Checking the device connection’.)
ScreenElementDescription.png Knowledgebase The ‘’’ ‘Knowledgebase’ button’’’ can be used to open a new web-browser window which will show the RadiWiki page about that device driver. That RadiWiki page can contain additional information or a detailed explanation of all the advanced settings.
Now we can conclude that:
4. Graphs configuration
5. Database configuration
Introduction
Select
   Menu.png Start
      Menu.png Settings
         Menu.png Control Panel
            Menu.png ODBC Data Sources
ScreenElementDescription.png Data Source Name This just a name for the setup you are making, name this Radimation, or another descriptive name for the used database
ScreenElementDescription.png Select Directory... Allows to select the directory in which the text based database files are stored
ScreenElementDescription.png Use Current Directory Overrules the selected directory to use the current directory. It is best to turn this checkbox off, and select a specific directory by using the Select Directory... button
ScreenElementDescription.png Extensions List Shows a list of filename extensions which will be used to determine the correct text files. Remove *.asc and *.tab from the extentions list
ScreenElementDescription.png Define Format... Will show the Define Text Format dialog, which can be used to define the format of the database as it is maintained in the text file
MySQL ODBC database
ScreenElementDescription.png Data Source Name An unique name that uniquely identifies the Data Source from the other available Data Sources.
ScreenElementDescription.png Description Any additional information regarding the Data Source
ScreenElementDescription.png TCP/IP Server The name (or IP address) of the MySQL server, to which a connection should be made
ScreenElementDescription.png Port The port-number to which the which the connection should be made. By default this is port-number 3306
ScreenElementDescription.png User The name of the MySQL user that should be used to connect to the MySQL Server
ScreenElementDescription.png Password The password of the MySQL user that should be used to connect to the MySQL Server
ScreenElementDescription.png Database The name of the MySQL database that should be connected to
ScreenElementDescription.png Test Will perform a connection test to the specified MySQL server and Database
ScreenElementDescription.png Details >> Will show additional configuration details for the MySQL connection. Your MySQL database administrator can help you with setting this details.
MSSQL ODBC database
ScreenElementDescription.png Name An unique name that uniquely identifies the Data Source from the other available Data Sources.
ScreenElementDescription.png Server The name (or IP address) of the MSSQL server, to which a connection should be made
ScreenElementDescription.png Windows NT Authentication Select this option to use the credential of the logged in user to connect to the MSSQL server.
ScreenElementDescription.png SQL Server Authentication Select this option to use a SQL Server specific username and password to connect to the MSSQL server.
ScreenElementDescription.png Client Configuration... Will show additional configuration details for the MSSQL connection. Your MSSQL database administrator can help you with setting this details.
ScreenElementDescription.png Login ID The name of the MSSQL user that should be used to connect to the MSSQL Server
ScreenElementDescription.png Password The password of the MSSQL user that should be used to connect to the MSSQL Server
ScreenElementDescription.png Change default database Enable the option, and specify or select the name of the database on the MSSQL Server that should be used.
ScreenElementDescription.png Test Data Source... Will perform a connection test, to determine if a connection with the MSSQL server can be established, using the configured parameters. A confirmation or error dialog with some additional information will be shown.
ScreenElementDescription.png Ok Stores the configured ODBC connection.
ScreenElementDescription.png Cancel Closes the dialogs without creating an ODBC connection.
6. Language Selection
7. Measurement Settings
Calibration
Required environment settings
8. Product Standard
Introduction
Adding a Product Standard
Add(ing) Basic Standard(s)
9. Basic Standard
Correction files
Creating correction files
   Menu.png File
      Menu.png New
         Menu.png Correction file
Adding and removing columns
Entering data points
9 29.69 10 29.68 etc.
9 29.69 10 29.68
Saving correction files
   Menu.png File
      Menu.png Save correction file
Attaching correction files
      Menu.png configuration
Correction file uses
Absorbing clamp: Clamp loss
  • Frequency
  • Correction
Or
  • Frequency
  • Attenuation
Or
  • Frequency
  • Gain
Amplifier: Maximum Input
  • Frequency
  • Correction
Or
  • Frequency
  • Power
Amplifier: Maximum Forward
  • Frequency
  • Correction
Or
  • Frequency
  • Power
Amplifier: Maximum Reflected
  • Frequency
  • Correction
Or
  • Frequency
  • Power
Antenna: Ant Gain vs Angle
  • Angle
  • Attenuation
Antenna: Antenna Efficiency
  • Frequency
  • Correction
Antenna: Antenna Factor
  • Frequency
  • Correction
Antenna: Antenna Gain
  • Frequency
  • Antenna gain
Antenna: GpsHt - AntHeight
  • Height
  • Frequency
  • Correction
  • Frequency
  • Correction
  • Frequency
  • Correction
Cable: Cable loss
  • Frequency
  • Correction
Or
  • Frequency
  • Attenuation
Or
  • Frequency
  • Gain
  • Frequency
  • Correction
This implies that:
Coupler: Forward Correction
  • Frequency
Or
  • Frequency
Or
  • Frequency
Coupler: Reflected Correction
  • Frequency
  • Correction
Or
  • Frequency
  • Attenuation
Or
  • Frequency
  • Gain
Current sensor: impedance
  • Frequency
Or
  • Frequency
Field sensor: Field offset
  • Frequency
or
  • Frequency
Field sensor: Field Multiply
  • Frequency
or
  • Frequency
LISN: Amplitude correction
  • Frequency
  • Correction
Powermeter: Power correction
  • Frequency
  • Correction
or
  • Frequency
  • Attenuation
or
  • Frequency
  • Gain
Pre amplifier: Amplifier Gain
  • Frequency
or
  • Frequency
or
  • Frequency
  • Frequency
  • Correction
  • Frequency
  • Correction
  • Frequency
  • Correction
