Error Report
(Redirected from Defect database)
Jump to: navigation, search
Reporting a problem when an error is shown
  1. On the RadiMation® Error Window, press the Report button.
  2. The Error Report window will be shown.
  3. Specify your own contact details, so we know how to contact you for a solution. As seen in the screenshot, you also must check the I agree that my provided data is used to improve the products and services of Raditeq checkbox.
  4. Ensure that all the fields do contain the correct information. If not all fields are filled you can not send or save the file. When information is missing, a red circle with a cross is displayed. If you hover over it with your mouse it will inform you what is missing in the form.
  5. Once the report information is filled in the buttons change colour, the report can now be send to the RadiMation® support team in 2 ways:
    • Send the report automatically using the Send button. A message will be shown that the error report is transmitted. You also will receive almost directly an e-mail from our ticket database with the ticket number that has been created for your error report.
    • Save the report with the Save button, and send the file over email to radimation-support@raditeq.com
Manually reporting an issue
   Menu.png Help
      Menu.png Report .
Reporting a RadiLog communication file only
  1. Open the RadiMation® logging tool (RadiLog) from the View menu in RadiMation®
  2. While the RadiLog tool is opened, reproduce the error.
  3. When the error has been logged, save the log file, by selecting 'File' and 'Save As...' from the menu.
  4. Send the .RadiLog file (zipped) to the RadiMation® support e-mail address radimation-support@raditeq.com
Sending larger files
