Rohde & Schwarz ESL 6
(Redirected from ESL6 performed tests)
Jump to: navigation, search
Front view of a Rohde & Schwarz ESL 6
Back view of a Rohde & Schwarz ESL 6
The Rohde & Schwarz ESL 6 device driver is a Power MeterSpectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Rohde & Schwarz ESL 6:
The frequency range of the Rohde & Schwarz ESL 6 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manual adjust the allowed frequency range of the Rohde & Schwarz ESL 6.
Be careful changing these setting as RadiMation® is no longer able to verify if the Rohde & Schwarz ESL 6 is used outside frequency range that is specified by the manufacturer. This may result to serious damage of your measurement device.
Performed Tests
The following tests has been performed on a R&S ESL6 to verify the functionality of the device driver
General
  • Model: Rohde & Schwarz ESL 6
  • Firmware version: 1.83 SP1
  • Preamplifier: not tested, option (B22) was not included
  • Tracking generator: not tested, option was not included
  • Communication over LAN: Ok
  • Test date: 2012 february 16th
Receiver mode
  • RBW: Ok (tested: 200 Hz, 9 kHz, 100 kHz, 120 kHz, 300 kHz, 1 Mhz)
  • Attenuator: 0, 5, 10, 15, 20, 25, 30, 35, 40, 45, 50 dB
  • Initial scan: Peak, Peak + Average, Peak + Average + RMS, Peak + Average + RMS + QP
  • Final Measurement Peak Detector: Ok
  • Final Measurement QP Detector: Ok
  • Final Measurement AVG Detector: Ok
  • Final Measurement RMS Detector: Ok
  • Linear frequency mode: Ok
  • Logarithmic frequency mode: Ok
  • Measure time: Ok
Analyser mode
  • RBW: Ok (tested: 200 Hz, 9 kHz, 10 kHz, 120 kHz, 300 kHz, 1 Mhz)
  • Reference Level: Ok
  • Sweeptime: Ok
  • VBW: Ok
  • Point count: 101 to 32001
