A-INFO Inc DS-3100 C
The A-INFO Inc DS-3100 C device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the A-INFO Inc DS-3100 C:
The frequency range of the A-INFO Inc DS-3100 C as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the A-INFO Inc DS-3100 C.
Be careful changing these settings as RadiMation® is no longer able to verify if the A-INFO Inc DS-3100 C is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: A-INFO Inc DS-3100 C
- Google image search: A-INFO Inc DS-3100 C
