A-INFO LB-62-20
The A-INFO LB-62-20 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the A-INFO LB-62-20:
The frequency range of the A-INFO LB-62-20 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the A-INFO LB-62-20.
Be careful changing these settings as RadiMation® is no longer able to verify if the A-INFO LB-62-20 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: A-INFO LB-62-20
- Google image search: A-INFO LB-62-20
