A.H. Systems SAS-521F-7
The A.H. Systems SAS-521F-7 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the A.H. Systems SAS-521F-7:
The frequency range of the A.H. Systems SAS-521F-7 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the A.H. Systems SAS-521F-7.
Be careful changing these settings as RadiMation® is no longer able to verify if the A.H. Systems SAS-521F-7 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: A.H. Systems SAS-521F-7
- Google image search: A.H. Systems SAS-521F-7
