A.H. Systems SAS-560
The A.H. Systems SAS-560 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the A.H. Systems SAS-560:
The frequency range of the A.H. Systems SAS-560 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the A.H. Systems SAS-560.
Be careful changing these settings as RadiMation® is no longer able to verify if the A.H. Systems SAS-560 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: A.H. Systems SAS-560
- Google image search: A.H. Systems SAS-560
