AELCO H1458
The AELCO H1458 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the AELCO H1458:
The frequency range of the AELCO H1458 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the AELCO H1458.
Be careful changing these settings as RadiMation® is no longer able to verify if the AELCO H1458 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: AELCO H1458
- Google image search: AELCO H1458
