AELCO H5000R
The AELCO H5000R device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the AELCO H5000R:
The frequency range of the AELCO H5000R as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the AELCO H5000R.
Be careful changing these settings as RadiMation® is no longer able to verify if the AELCO H5000R is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: AELCO H5000R
- Google image search: AELCO H5000R
