ARA LPB2513A
The ARA LPB2513A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ARA LPB2513A:
The frequency range of the ARA LPB2513A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ARA LPB2513A.
Be careful changing these settings as RadiMation® is no longer able to verify if the ARA LPB2513A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ARA LPB2513A
- Google image search: ARA LPB2513A
