ARC Seibersdorf PCD 8250
The ARC Seibersdorf PCD 8250 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the ARC Seibersdorf PCD 8250:
The frequency range of the ARC Seibersdorf PCD 8250 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the ARC Seibersdorf PCD 8250.
Be careful changing these settings as RadiMation® is no longer able to verify if the ARC Seibersdorf PCD 8250 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: ARC Seibersdorf PCD 8250
- Google image search: ARC Seibersdorf PCD 8250
