Aaronia BicoLOG 20100X
The Aaronia BicoLOG 20100X device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia BicoLOG 20100X:
The frequency range of the Aaronia BicoLOG 20100X as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Aaronia BicoLOG 20100X.
Be careful changing these settings as RadiMation® is no longer able to verify if the Aaronia BicoLOG 20100X is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Aaronia BicoLOG 20100X
- Google image search: Aaronia BicoLOG 20100X
