Aaronia HyperLOG 30100X
The Aaronia HyperLOG 30100X device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia HyperLOG 30100X:
The frequency range of the Aaronia HyperLOG 30100X as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Aaronia HyperLOG 30100X.
Be careful changing these settings as RadiMation® is no longer able to verify if the Aaronia HyperLOG 30100X is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Aaronia HyperLOG 30100X
- Google image search: Aaronia HyperLOG 30100X
