Aaronia OmniLOG 30800
The Aaronia OmniLOG 30800 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Aaronia OmniLOG 30800:
The frequency range of the Aaronia OmniLOG 30800 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Aaronia OmniLOG 30800.
Be careful changing these settings as RadiMation® is no longer able to verify if the Aaronia OmniLOG 30800 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Aaronia OmniLOG 30800
- Google image search: Aaronia OmniLOG 30800
