Advantest R3261B
The Advantest R3261B device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Advantest R3261B:
The frequency range of the Advantest R3261B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Advantest R3261B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Advantest R3261B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
