Advantest R3261D
The Advantest R3261D device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Advantest R3261D:
The frequency range of the Advantest R3261D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Advantest R3261D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Advantest R3261D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
