Advantest TR4133(7.2E9 to 15.2E9 Hz)
The Advantest TR4133(7.2E9 to 15.2E9 Hz) device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Advantest TR4133(7.2E9 to 15.2E9 Hz):
The frequency range of the Advantest TR4133(7.2E9 to 15.2E9 Hz) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Advantest TR4133(7.2E9 to 15.2E9 Hz).
Be careful changing these settings as RadiMation® is no longer able to verify if the Advantest TR4133(7.2E9 to 15.2E9 Hz) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Advantest TR4133(7.2E9 to 15.2E9 Hz)
- Google image search: Advantest TR4133(7.2E9 to 15.2E9 Hz)
