The Advantest TR 4511 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Advantest TR 4511:
The frequency range of the Advantest TR 4511 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Advantest TR 4511.
Use default start frequency
Custom start frequency
Use default stop frequency
Custom stop frequency
Be careful changing these settings as RadiMation® is no longer able to verify if the Advantest TR 4511 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
