Agilent 87405A
The Agilent 87405A device driver is a Pre-Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent 87405A:
The frequency range of the Agilent 87405A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent 87405A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent 87405A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
