Agilent Technologies 33509B
The Agilent Technologies 33509B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies 33509B:
The frequency range of the Agilent Technologies 33509B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies 33509B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies 33509B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Agilent Technologies 33509B
- Google image search: Agilent Technologies 33509B
