Agilent Technologies 4408B
The Agilent Technologies 4408B device driver is a Spectrum Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies 4408B:
The frequency range of the Agilent Technologies 4408B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies 4408B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies 4408B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Agilent Technologies 4408B
- Google image search: Agilent Technologies 4408B
