Agilent Technologies 83630B
The Agilent Technologies 83630B device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies 83630B:
The frequency range of the Agilent Technologies 83630B as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies 83630B.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies 83630B is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The Agilent 83630B is a signal generator that is part of the Agilent 836xxB series. See the page of the Agilent 836xxB series for more information.
