Agilent Technologies 8648D
The Agilent Technologies 8648D device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies 8648D:
The frequency range of the Agilent Technologies 8648D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies 8648D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies 8648D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Agilent Technologies 8648D
- Google image search: Agilent Technologies 8648D
