Agilent Technologies 8753
The Agilent Technologies 8753 device driver is a Signal Generator, Spectrum Analyser, Network Analyser which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies 8753:
The frequency range of the Agilent Technologies 8753 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies 8753.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies 8753 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Agilent Technologies 8753
- Google image search: Agilent Technologies 8753
