Agilent Technologies E8241A
The Agilent Technologies E8241A device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies E8241A:
The frequency range of the Agilent Technologies E8241A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies E8241A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies E8241A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Agilent Technologies E8241A
- Google image search: Agilent Technologies E8241A
