Agilent Technologies E8247C-520
The Agilent Technologies E8247C-520 device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies E8247C-520:
The frequency range of the Agilent Technologies E8247C-520 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies E8247C-520.
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies E8247C-520 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Agilent Technologies E8247C-520
- Google image search: Agilent Technologies E8247C-520
