Agilent Technologies N5181A-501(IVI)
The Agilent Technologies N5181A-501(IVI) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies N5181A-501(IVI):
The frequency range of the Agilent Technologies N5181A-501(IVI) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies N5181A-501(IVI).
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies N5181A-501(IVI) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Agilent Technologies N5181A-501(IVI)
- Google image search: Agilent Technologies N5181A-501(IVI)
