Agilent Technologies N5181A-501 (IVI)
The Agilent Technologies N5181A-501 (IVI) device driver is a Signal Generator which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Agilent Technologies N5181A-501 (IVI):
The frequency range of the Agilent Technologies N5181A-501 (IVI) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Agilent Technologies N5181A-501 (IVI).
Be careful changing these settings as RadiMation® is no longer able to verify if the Agilent Technologies N5181A-501 (IVI) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
