Ailtech 93490-1
The Ailtech 93490-1 device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Ailtech 93490-1:
The frequency range of the Ailtech 93490-1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Ailtech 93490-1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Ailtech 93490-1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Ailtech 93490-1
- Google image search: Ailtech 93490-1
