Amplifier Research 1000LM (Philips Medical)
The Amplifier Research 1000LM (Philips Medical) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 1000LM (Philips Medical):
The frequency range of the Amplifier Research 1000LM (Philips Medical) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 1000LM (Philips Medical).
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 1000LM (Philips Medical) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
