Amplifier Research 1000W1000D
The Amplifier Research 1000W1000D device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 1000W1000D:
The frequency range of the Amplifier Research 1000W1000D as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 1000W1000D.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 1000W1000D is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research 1000W1000D
- Google image search: Amplifier Research 1000W1000D
