Amplifier Research 100W1000BM1
The Amplifier Research 100W1000BM1 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 100W1000BM1:
The frequency range of the Amplifier Research 100W1000BM1 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 100W1000BM1.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 100W1000BM1 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research 100W1000BM1
- Google image search: Amplifier Research 100W1000BM1
