Amplifier Research 2000LA
The Amplifier Research 2000LA device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 2000LA:
The frequency range of the Amplifier Research 2000LA as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 2000LA.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 2000LA is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research 2000LA
- Google image search: Amplifier Research 2000LA
