Amplifier Research 2500A250A (Remote Controlled)
The Amplifier Research 2500A250A (Remote Controlled) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 2500A250A (Remote Controlled):
The frequency range of the Amplifier Research 2500A250A (Remote Controlled) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 2500A250A (Remote Controlled).
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 2500A250A (Remote Controlled) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research 2500A250A (Remote Controlled)
- Google image search: Amplifier Research 2500A250A (Remote Controlled)
