Amplifier Research 250W250B (EVPU CDC)
The Amplifier Research 250W250B (EVPU CDC) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 250W250B (EVPU CDC):
The frequency range of the Amplifier Research 250W250B (EVPU CDC) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 250W250B (EVPU CDC).
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 250W250B (EVPU CDC) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research 250W250B (EVPU CDC)
- Google image search: Amplifier Research 250W250B (EVPU CDC)
