Amplifier Research 25A250A
The Amplifier Research 25A250A device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 25A250A:
The frequency range of the Amplifier Research 25A250A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 25A250A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 25A250A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research 25A250A
- Google image search: Amplifier Research 25A250A
