Amplifier Research 25S1G4 (60% Gain)(Remote controlled)
The Amplifier Research 25S1G4 (60% Gain)(Remote controlled) device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 25S1G4 (60% Gain)(Remote controlled):
The frequency range of the Amplifier Research 25S1G4 (60% Gain)(Remote controlled) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 25S1G4 (60% Gain)(Remote controlled).
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 25S1G4 (60% Gain)(Remote controlled) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
The following tabs are available in the advanced configuration of the Amplifier Research 25S1G4 (60% Gain)(Remote controlled).
ScreenElementDescription.svg Invert Gain Command The gain of an Amplifier Research amplifier can be remotely configured. However for some Amplifier Research amplifiers the "G0000" command to set the gain is used to select the maximum gain, while for other Amplifier Research amplifiers, the "G0000" command is used to select the minimum gain. It cannot be determined for a specific Amplifier Research amplifier, which gain setting should be used for a maximum gain. The 'Invert Gain Command' checkbox can however be used to use inverted gain logic to select the maximum gain. If it is observed that the amplifier is using minimum gain, then toggle the checkbox to send the opposite gain command to select the maximum gain for this amplifier.
