Amplifier Research 500W1000BM4
The Amplifier Research 500W1000BM4 device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 500W1000BM4:
The frequency range of the Amplifier Research 500W1000BM4 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 500W1000BM4.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 500W1000BM4 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
