Amplifier Research 7500L
The Amplifier Research 7500L device driver is a Amplifier which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research 7500L:
The frequency range of the Amplifier Research 7500L as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research 7500L.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research 7500L is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research 7500L
- Google image search: Amplifier Research 7500L
