Amplifier Research AT1080 (MEOB)
The Amplifier Research AT1080 (MEOB) device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research AT1080 (MEOB):
The frequency range of the Amplifier Research AT1080 (MEOB) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research AT1080 (MEOB).
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research AT1080 (MEOB) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research AT1080 (MEOB)
- Google image search: Amplifier Research AT1080 (MEOB)
