Amplifier Research AT4000 (Vertical) (KRE 2720)
The Amplifier Research AT4000 (Vertical) (KRE 2720) device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research AT4000 (Vertical) (KRE 2720):
The frequency range of the Amplifier Research AT4000 (Vertical) (KRE 2720) as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research AT4000 (Vertical) (KRE 2720).
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research AT4000 (Vertical) (KRE 2720) is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
