Amplifier Research DC2500A
The Amplifier Research DC2500A device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research DC2500A:
The frequency range of the Amplifier Research DC2500A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research DC2500A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research DC2500A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research DC2500A
- Google image search: Amplifier Research DC2500A
