Amplifier Research DC2500AM2
The Amplifier Research DC2500AM2 device driver is a Coupler which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research DC2500AM2:
The frequency range of the Amplifier Research DC2500AM2 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research DC2500AM2.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research DC2500AM2 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research DC2500AM2
- Google image search: Amplifier Research DC2500AM2
