Amplifier Research FM 5004
The Amplifier Research FM 5004 device driver is a Field Sensor which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research FM 5004:
| The minimum amount of measurements in the measure loop. Continues to loop even if field strength level is stable. |
| If the measured field strength between each measurement in the measurement-loop, is less than this value. The measured field strength is stable. The measurement-loop will then stop. |
The frequency range of the Amplifier Research FM 5004 as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research FM 5004.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research FM 5004 is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research FM 5004
- Google image search: Amplifier Research FM 5004
The AR FM 5004 is a 4 probe controller.
know bugs
In embedded version 3.7 the auto command for the range does not work correctly. According to the manual you can send an A for auto, this does not work. Strangely sending 5 instead of A in the range command solves the problem.
