Amplifier Research FSA
The Amplifier Research FSA device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research FSA:
The frequency range of the Amplifier Research FSA as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research FSA.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research FSA is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research FSA
- Google image search: Amplifier Research FSA
