Amplifier Research TC1510A
The Amplifier Research TC1510A device driver is a Antenna which is supported by RadiMation®.
The following tabs are available in the advanced configuration of the Amplifier Research TC1510A:
The frequency range of the Amplifier Research TC1510A as provided by the manufacturer is shown and selected as default. It is possible to overrule these frequencies and to manually adjust the allowed frequency range of the Amplifier Research TC1510A.
Be careful changing these settings as RadiMation® is no longer able to verify if the Amplifier Research TC1510A is used outside frequency range that is specified by the manufacturer. This may result in serious damage to your measurement device.
- Google search: Amplifier Research TC1510A
- Google image search: Amplifier Research TC1510A
